lga 775 volt mode - Overclock.net
post #1 of 7 Old 09-17-2006, 01:46 PM - Thread Starter
733mhz
flank's Avatar
Quoted: 0 Post(s)
Liked: 2
i found out how to mod the lga for limiting boards and i was woundering(i overclock with clockgen) if having the voltage really high and not having the speed set high will this damage the cpu?
flank is offline
post #2 of 7 Old 09-17-2006, 01:53 PM
I have many leatherbound books
Quoted: 0 Post(s)
Liked: 276
kidwolf909 is offline
post #3 of 7 Old 09-17-2006, 02:11 PM - Thread Starter
733mhz
flank's Avatar
Quoted: 0 Post(s)
Liked: 2
am gonna take it to 1.48 its at 1.3 stock is that fine or too much then
flank is offline
post #4 of 7 Old 09-17-2006, 05:23 PM - Thread Starter
733mhz
flank's Avatar
Quoted: 0 Post(s)
Liked: 2
on tomshardware the got it at 1.6
flank is offline
post #5 of 7 Old 09-17-2006, 05:44 PM
aaa
1.3ghz
aaa's Avatar
Quoted: 0 Post(s)
Liked: 30
High voltage is risky either way, the speed doesn't change much (if anything slower would be marginally safer because of less heat).
aaa is offline
post #6 of 7 Old 09-18-2006, 04:10 PM
333mhz
rank22's Avatar
Quoted: 0 Post(s)
Liked: 0
well i used that mod what but my temps are gine i have a Scythe SCINF and my temps are 36 idle 62 load on a pd805 and my voltage is set to 1.47 is it doomed cuz i aint unmoding too much work and am only keeping the prossesor for a year and the speed is 3.969 http://valid.x86-secret.com/show_oc?id=122743
rank22 is offline
post #7 of 7 Old 10-15-2006, 05:45 PM
4.0ghz
sandiegoskyline's Avatar
Quoted: 0 Post(s)
Liked: 169
1.48 is fine, 1.55v is the max for 90nm
cooling will become the issue above 1.475v
You fail.
sandiegoskyline is offline
