Truecrypt unable to mount drive - Overclock.net
post #1 of 11 Old 05-20-2011, 07:54 AM - Thread Starter
AMD Overclocker
Atomfix's Avatar
Quoted: 0 Post(s)
Liked: 193
I've created a seperate partition on my Steam Drive to encrypt it with TrueCrypt so that I can keep my personal files within.
Trying to select a hidden drive and the volume, and it comes up with the error
Error: Cannot Mount Volume. The Host File/Device is already in use.
Attempt to mount with exclusive access failed as well.
And yes, Iv'e ran the TrueCrypt program with Admin etc...., Why would something be using the drive as Iv'e just freshly created that partition?
PSN: ATO3FIX
STEAM: Atomfix
Chimp Challenge 2 x Participant
Atomfix is offline
post #2 of 11 Old 05-20-2011, 07:56 AM
☰ Syrillian
Quoted: 0 Post(s)
Liked: 537
Unmount it from windows disk manager.
Chimp Challenge Championship Team  Chimp Challenge 2 x Participant  2 Million+ Folding at Home points
RonindeBeatrice is offline
post #3 of 11 Old 05-20-2011, 07:59 AM - Thread Starter
AMD Overclocker
Atomfix's Avatar
Quoted: 0 Post(s)
Liked: 193
Iv'e deleted the drives letter, and I'm gueesing that the only way to unmount it. Still the same after I deleted the Drive's letter
PSN: ATO3FIX
STEAM: Atomfix
Atomfix is offline
post #4 of 11 Old 05-20-2011, 08:16 AM - Thread Starter
AMD Overclocker
Atomfix's Avatar
Quoted: 0 Post(s)
Liked: 193
PSN: ATO3FIX
STEAM: Atomfix
Atomfix is offline
post #5 of 11 Old 05-20-2011, 08:19 AM
Linux Lobbyist
Greensystemsgo's Avatar
Quoted: 0 Post(s)
Liked: 192
restart? hope you had a backup of your encrypted data :/
Overclock.net 10 Year Member
Greensystemsgo is offline
post #6 of 11 Old 05-20-2011, 08:21 AM - Thread Starter
AMD Overclocker
Atomfix's Avatar
Quoted: 0 Post(s)
Liked: 193
I done a restart, and there's nothing in the partition, Iv'e just split 7GB from my 500GB Steam DATA drive.
What I want to do is encrypt that 7GB partition that I have just created and it's not letting me do it frown.gif
Iv'e tried removeing the drives letter name and replaceing it back with the :J letter.... frown.gif *crys*
PSN: ATO3FIX
STEAM: Atomfix
Atomfix is offline
post #7 of 11 Old 05-20-2011, 08:31 AM - Thread Starter
AMD Overclocker
Atomfix's Avatar
Quoted: 0 Post(s)
Liked: 193
It seems to be Encrypting now, I had to select the normal mode, I coulden't use the Direct Mode for some reason :/
EDIT: It didn't work again, as soon as it finished formatting the partition on 100%, it said failed to mount the outer volume system frown.gif
PSN: ATO3FIX
STEAM: Atomfix
Atomfix is offline
post #8 of 11 Old 05-20-2011, 08:43 AM
Linux Lobbyist
Quoted: 0 Post(s)
Liked: 192
hrm, how did you partition it to begin with? I would recommend using an independent drive, avoiding the need for partitions and what not.
post #9 of 11 Old 05-20-2011, 08:45 AM
☰ Syrillian
Quoted: 0 Post(s)
Liked: 537
I would delete the partition in windows, then run the truecrypt wizard and point it at this unallocated space.
post #10 of 11 Old 05-20-2011, 09:09 AM
4.0ghz
esocid's Avatar
Quoted: 0 Post(s)
Liked: 232
You can't do Direct mode unless you already have a Truecrypt volume and want to make a hidden volume inside of it. I'm not entirely sure why it fails to mount it. Are you using the wizard, or doing it all manually?
esocid is offline
