HD204UI Problem. - Overclock.net
post #1 of 7 Old 10-13-2011, 04:11 AM - Thread Starter
733mhz
SmartedPAnda's Avatar
Quoted: 0 Post(s)
Liked: 1
Basically, want you guys to lie to me. Tell me everything's A-OK.
My Samsung HD204UI 2TB,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152245
has sector errors, and problems. Everytime I try to access a file it hangs, freezes my computer, I've tried different ports, different SATA power cables, and each time it either freezes, works fine for 30 seconds, or I get a Windows Error.
I've tried updating the firmware, made it worst, than found out I had the better firmware when it arrived from the factory. Also, can't find the HDD Manufacturing date for the life of me.
Any suggestions? I just wanna back up my 1.35TB of my files or a temp fix so I can wipe it, and possibly RMA it.
4.0 GHz Overclock Club // I <3 Mechanical Keyboard
TF2//CS:S//Gaming Clan; BrotherHood of Slaughter
Battlestation/ComputerArt; BattleDesks.Tumblr
SmartedPAnda is offline
post #2 of 7 Old 10-13-2011, 04:16 AM
Like I'm sippin' on smoke
Wheezo's Avatar
Quoted: 0 Post(s)
Liked: 142
Warning: Spoiler! (Click to show)
.:: Brittish people rule... If you don't believe me, watch Top Gear ::.
"Hold on to your spine!"- Jeremy Clarkson
50 Million+ Folding at Home points  Chimp Challenge 3 x Participant  Foldathon Folder - 2012 Participant  Foldathon Folder - 2013 Participant  BGB Participant 2014  BOINC Pentathlon 6x Participant
Wheezo is offline
post #3 of 7 Old 10-13-2011, 04:30 AM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 1
Kinda wanna back up my stuff (which i can't), before I send it to a company which states all info are theirs once it's in their hands.
post #4 of 7 Old 10-13-2011, 05:18 AM
Storage Nut
Kramy's Avatar
Quoted: 0 Post(s)
Liked: 1075
Grab the trial of HDTune Pro and check the Health tab. Post a screenshot of all the SMART info there.
Are you willing to attempt bootable tools, or do you want a way to pull your stuff off from Windows?
If limited to Windows... you need a smarter File Copy program than what's built-in. Try TeraCopy:
http://www.codesector.com/teracopy.php
It's designed for copying terabytes of files. It doesn't seem to mind waiting for drives to unfreeze. I/O errors shouldn't stop it - it'll just notify you at the end that a few files didn't make it. Then you can retry those files or ignore them. Give it a shot and see if it can cope with your HDD, or if your HDD is too far gone. If it works, no need to break out the bootable tools. If it doesn't... let us know and we'll try to come up with other methods.
Kramy is offline
post #5 of 7 Old 10-13-2011, 02:20 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 1
Thanks Kramy.
Here's my Screenshot.
It kept lagging/stuttering my computer but here it is;
I'll try TeraCopy, I actually had a copy but uninstalled it because of problems!
Thanks, I also have CrystalDiskInfo if that helps.
post #6 of 7 Old 10-13-2011, 08:05 PM
Storage Nut
Kramy's Avatar
Quoted: 0 Post(s)
Liked: 1075
Yeah, that drive is well on its way to being dead. Read Errors, Write Errors, Bad Sectors. frown.gif
The Data column is the column to pay attention to - 01, 05, C4, C5, C8 indicate failure.
I hope you're able to get off what you need. If copying doesn't work, there is a cmdline tool called ddrescue which can be run from bootable Linux CDs (such as SystemRescueCD) - I'll track down a link and instructions if you want me to.
Kramy is offline
post #7 of 7 Old 10-13-2011, 09:21 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 1
If you could, TeraCopy crashed twice, and third time it's stuck at 2.49% in transferring of 400GB worth of files.
