Help! I dropped my external 2TB HDD! - Page 3 - Overclock.net
post #21 of 29 Old 03-01-2012, 07:14 PM
No keyboard detected! Press F1 to continue..
Schmuckley's Avatar
Quoted: 0 Post(s)
Liked: 698
I dropped a hard drive by accident..it smacked the floor..it's done..Mechanical hdds don't take shock very well
Schmuckley is offline
post #22 of 29 Old 03-01-2012, 07:19 PM
News Fiend
Awsan's Avatar
Quoted: 0 Post(s)
Liked: 107
i need to sleep now O.O but still i found these two not the best price out there but its only an idea
http://www.amazon.com/Western-Digital-Elements-Desktop-External/dp/B002QEBMCI/ref=pd_cp_e_2
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148848
both are the same prices in every major site so tomorrow i might find for you a steal thumb.gif
Early Oneplus 3 adopter feel free to ask me anything
Owner Of The Darth Vader 920
Fuhrer 3770K! (Click to show)
Wut?
A i7 3770K on a intel Z87 MoBo???
in germany the fuhrer 3770k fits into any mobo, even 775
In Soviet Russia, sockets fits into you.
Awsan is online now
post #23 of 29 Old 03-01-2012, 07:22 PM
4.0 GHz
SeW800's Avatar
Quoted: 0 Post(s)
Liked: 2
Was it working (powered on) at the time when you dropped it?
I had a 500GB drive drop while it wasn't powered on, and it's still working a year later.
SeW800 is offline
post #24 of 29 Old 03-01-2012, 07:27 PM
BarryBadrinath's Avatar
Quoted: 0 Post(s)
Liked: 13
Read this: Save a Failed Hard Drive in Your Freezer, Redux
The same thing happened to one of my external Seagate drives. I removed it from the enclosure and stuck it into the freezer for a day. I was able to recover all my files before the drive failed again.
BarryBadrinath is offline
post #25 of 29 Old 04-15-2012, 03:10 PM
First Time Build
onslaught_'s Avatar
Quoted: 0 Post(s)
Liked: 1
Any luck getting your external hard drive to work? I'm a fool for not backing up my external hd frown.gif
....I have 3.5 HD in an enclosure sitting on top of my sub woofer...my roommate accidentally knocked it down while it was on...and now it won't work frown.gif
hopefully someone can give me advice on what steps I should take to recover my data...
..it was on when it dropped...but i had no idea my roommate knocked it down..so i kept using it and noticed latency playing music off my itunes...
anyway my roommate finally told me and now its messed up!
Status:
MY PC recognizes the HD...but like OPs it asks to format it before i can use it.
I hear no clicking noises when it powers on..
The power button on is kind of messed up...I can power it on but I can't power it off...its like the button gets stuck.
I've ordered a new enclosure and I'm going to try and put it in there to see if it works.
Can anyone tell me what my next steps should be?
1) Try some of the recovery software others mentioned here
2) Possibly bring it to NCIX and get them to recover the data
3) punch my roommate and slap myself silly for not backing up my data frown.gif
Music and movies...are all replaceable..but my personal pictures..and videos...cannot.. :/
Thanks in advanced for anyone who can shed some light on this!
Cheers <3
onslaught_ is offline
post #26 of 29 Old 04-15-2012, 03:29 PM
Storage Nut
Kramy's Avatar
Quoted: 0 Post(s)
Liked: 1075
Sometimes when drives get dropped the head can get wedged into the platter.
People may recommend the "freezer trick" or dropping it again - both tricks have a small chance of getting the head free, but won't do anything for other methods of failure.
I would recommend removing the drive from its enclosure and connecting it directly to a desktop PC. That takes one factor out of the equation. If it spins up and works, grab your most important data as quickly as possible. If not, then you may have to try other things. (such as the above - google for more info)
If it doesn't show up as formatted, try using TestDisk to recover the partition.
That's all I can really recommend. When you drop a drive, there's a high chance something will go wrong. I suppose hitting it at some angles would be alright, but if it lands flat while running you're pretty much screwed. That's guaranteed to cause platter damage.
Kramy is offline
post #27 of 29 Old 04-15-2012, 03:33 PM
rawfuls's Avatar
Quoted: 0 Post(s)
Liked: 74
If you know somebody with SpinRite, give that a try.
Or you may have other means of coming across it.
When it's off and you drop it, chances of it dying is lower than when you drop it, while it's on, and KEEP using it.
rawfuls is offline
post #28 of 29 Old 04-15-2012, 07:51 PM
First Time Build
onslaught_'s Avatar
Quoted: 0 Post(s)
Liked: 1
303
Hey guys thanks!
Just to give you all an update..I've managed to salvage my pictures using Testdisk! Awesome program!!!
Just out of curiosity..I've been running the program for about 6hrs now...and it's still Copying, please wait.."
Will the program give me a message saying it's finished? It doesn't really say that in the Guide I followed tongue.gif
I'm not in a rush or anything...I just have no experience in using this program...anyway so far so good smile.gif thanks again for all the help and OP for creating this tread!
I'm going to purcchase more HDs and mirror all my data from now on!
Cheers!
post #29 of 29 Old 04-15-2012, 08:04 PM
Storage Nut
Kramy's Avatar
Quoted: 0 Post(s)
Liked: 1075
I don't know the answer to your last question, but I can tell you that it will take a long time to backup or copy most of a large hard drive. 6 hours isn't unreasonable - but if your drive is slightly damaged, it might slow down when it encounters bad sectors, making it take even longer.
I'd say leave it overnight and figure out what it's doing (or not doing) in the morning.
Kramy is offline
