HDD No 80 Conductor help - Page 2 - Overclock.net
post #11 of 32 Old 10-13-2006, 02:25 AM
4.0ghz
RuSo's Avatar
Quoted: 0 Post(s)
Liked: 98
yes an ATA 100/133 cable has 80 cond. cable have you tried your other IDE connection on the mobo? and did you check the bios settings, something in the hard drive options like UDMA 6.....the drivers are located in the N-Force driver installation from Nvidia....
RuSo is offline
post #12 of 32 Old 10-13-2006, 02:26 AM
Semi-Retired OCer
PROBN4LYFE's Avatar
Quoted: 0 Post(s)
Liked: 603
Should look like this...
Under IDE ATA/ATAPI drive you should see the driver selection.
PROBN4LYFE is offline
post #13 of 32 Old 10-13-2006, 02:34 AM - Thread Starter
733mhz
Scorpion_WR's Avatar
Quoted: 0 Post(s)
Liked: 7
I have a WDC1600JB, what should BIOS settings be for it? 160GB drive. I am a HDD n00b. Thanks for the help...
Scorpion_WR is offline
post #14 of 32 Old 10-13-2006, 02:45 AM
Semi-Retired OCer
PROBN4LYFE's Avatar
Quoted: 0 Post(s)
Liked: 603
ATA 133...Ultra or Parallel DMA
Depending on chipset version...
Scorpion_WR likes this.
post #15 of 32 Old 10-13-2006, 02:49 AM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 7
Chipset is nForce4.
post #16 of 32 Old 10-13-2006, 02:57 AM
Moderator
gonX's Avatar
Quoted: 1 Post(s)
Liked: 1156
Originally Posted by Scorpion_WR
So if my cable says ATA 100/133 does that mean its an 80 cond. cable? That is what I an running ATM, and still have error.
Yes, definely.
40 cond. cable is larger, and uses 40 wires, compared to a 80 cond. cable.
You will run ATA33/66 if it can't spot a cond. 80 cable, because if it ran ATA100+ with a 40 cond. cable, each cable would infere with eachother.
So yes, if your cable says ATA133, it MUST be a 80 cond. cable.
Chimp Challenge Participant
gonX is offline
post #17 of 32 Old 10-13-2006, 03:06 AM
4.0ghz
RuSo's Avatar
Quoted: 0 Post(s)
Liked: 98
page 92 chapter 4.3.5 and page 109 this should help you out for bios settings
http://dlsvr01.asus.com/pub/ASUS/mb/...i_series_b.pdf
RuSo is offline
post #18 of 32 Old 10-13-2006, 03:11 AM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 7
OK, thanks all. Cable is definately good. Reinstalled the nVidia chipset drivers, still same error. BIOS reports UMDA 5. Just found in the manual that it says the gray connector is for the master, and the black connector is for the slave. Does this sound right?
post #19 of 32 Old 10-13-2006, 03:14 AM
4.0ghz
RuSo's Avatar
Quoted: 0 Post(s)
Liked: 98
the connection on the end of the IDE cable is master the other one is slave fit the connector with the longest end in the mobo
RuSo is offline
post #20 of 32 Old 10-13-2006, 03:17 AM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 7
That is what I thought. That is how it was too. Right now there is only a 1 drive cable in there. PC Wizard 2006 reports:
UDMA Mode max. : 5 (ATA-100)
UDMA Mode Enabled : 5 (ATA-100)
