[The Tech Report] Radeon HD 7950 vs. GeForce GTX 660 Ti revisited - Page 51 - Overclock.net
post #501 of 745 Old 12-09-2012, 05:00 PM
atomicmew's Avatar
Quoted: 0 Post(s)
Liked: 30
Originally Posted by Telimektar View Post
Is Vsync forced via D3D Overrider with modern GPUs free of input lag ? (serious question). Everytime I used it it always made some sort of input lag (which is far more annoying to me than the tearing). One of the few develepors that have perfect Vsync is Capcom (in my experience at least), almost all other games I ever played had input lag with Vsync turned on.
I haven't noticed any additional input lag with D3D overrider in any of the games I play compared to vsync off. I can't say for sure, since I don't know of a method of testing that. But according to the anandtech article, there is theoretically little to no input lag due to triple buffering.
What I can tell you for sure is that there is no performance hit when using forced triple buffering (Guild wars 2/Unigine Heaven benchmarked with FRAPS).
So unless you are playing at 120 FPS, there is no reason not to have it on. If you are playing at around 60 FPS or lower, it's superior to adaptive vsync in every way. It is also superior to no vsync in every way and superior to frame rate limiting in every way.
atomicmew is offline
post #502 of 745 Old 12-09-2012, 05:14 PM
Graphics Card Aficionado
tsm106's Avatar
Quoted: 0 Post(s)
Liked: 1381
Originally Posted by brettjv View Post
Originally Posted by di inferi View Post
This is not my card, overclocking it right now, but....
http://www.overclock.net/t/884072/post-your-3dmark11-scores/3200_20#post_18783296 Warning: Spoiler! (Click to show)
There is really no reason to have a "bench off" in response to this review....
The proof is already in the benches in the thread I have posted.
Wow, that's pretty friggin epic. I had no idea that 7950's were doing 11.8K GPU score on 3dMark11 nowadays. I do rather wish he'd posted his clocks, whether or not that's air-cooled, etc, but still ... awesome-sauce.
Might have to pick me up a (or couple of) 7950's at some point.
But ... all due respect ... we can go ahead do bench-off's if we feel like it wink.gif
Wow ... that's 10.5% better than my old GTX 670 eek.gif.
That is a significant difference considering HD 7950 is cheaper ...
It's still surprising to me to see ppl remark on the clock for clock speed differences. You guys didn't know this? The 7950 runs the same silicon, it's only handicap is the lower binning, limited shaders and heavy underclock. Kepler needs over 100-150mhz overclock to match.
Originally Posted by tsm106 View Post
**Just updated with the latest 310.54 driver.
I got an pm from Junkboy asking to compare my two rigs since I run both 7970s and a 680.
Both cards clocked to 1300 core and 1750 memory (7000 effective). The 680 is actually running slightly higher clocks, 1305/1752 -ish. Systems are very close, almost identical in the most respects, SSD RAID 0, 16GB Samsung wonder ram @ 2133 (same timings), watercooled cpu/gpu/vrm, etc...
The 7970 setup. You can also look at the rigs in my sig rig.
3930k is limited to 4 cores. I ran cinebench to confirm performance is the same. They should be since it's the same IPC. After running cinebench, I have to barf a little when I think about how much two cores costs in relation to the 3820 lol.
3820@4.8ghz (37x 130) - 9.32pts
3930K@4.8ghz (48x100) - 9.35pts
Benches, 680 list first/top:
3dmark 11
310.33 - P11496
http://www.3dmark.com/3dm11/4811914
310.54 - P11342
http://www.3dmark.com/3dm11/4922060
forgot to make a screen, will update with a screen
12.11B4 - P12283
http://www.3dmark.com/3dm11/4811918
**The physics scores match up pretty darn good all things considered.
Heaven 3.0
310.33 - 61.5 FPS
310.54 - 61.5 FPS
12.11B4 - 64.9 FPS
Metro 2033
310.33 - 85.37 FPS
310.54 - 84.65 FPS
12.11B4 - 106.47 FPS
Sleeping Dogs
310.33 - 54.6 FPS
310.54 - 54.0 FPS
12.11B4 - 69.1 FPS
**I had to run the 7970 at 1295/1750 on 12.11 whilst using Afterburner. AB cannot feed as much voltage at that clock to the 7970 and 12.11 betas are finicky as all get out. Nv drivers really are a set it and forget type of experience. It's such a contrast.
Batman AC
310.33 - 104 FPS
310.54 - 104 FPS
12.11B4 - 120 FPS
Batman settings:
I have to run out right now but when I get back later, I will add screens of in game settings.
Ok, got Batman settings posted. Added 3dmark links.
Chimp Challenge 2 x Participant
tsm106 is offline
post #503 of 745 Old 12-09-2012, 06:31 PM
PC Gamer
dph314's Avatar
Quoted: 0 Post(s)
Liked: 114
I actually get sucked into these as well, reading for countless pages, neglecting work, ha. I'd definitely get a lot more work done if these threads didn't exist.
Originally Posted by maarten12100
Originally Posted by dph314
Is it weird that I'm slightly aroused?
No, it isn't. Epeen is rising!
10 Million+ Folding at Home points
dph314 is offline
post #504 of 745 Old 12-09-2012, 06:46 PM
Since 1975!
mcg75's Avatar
Quoted: 0 Post(s)
Liked: 311
It makes absolutely no sense to say heavy underclock. If each and every 7950 could reach what some members of OCN think they can, AMD would be releasing cards with 1050-1100 mhz boost instead of 925. In which case, no 12.11 drivers would have been needed to even the playing field and AMD would have been winning benches right from the getgo.
mcg75 is offline
post #505 of 745 Old 12-09-2012, 06:57 PM
sugarhell's Avatar
Quoted: 3 Post(s)
Liked: 565
7970 comes with pretty high clocks in custom models. As it looks they dont give 7950 some love too tongue.gif
No I said if Vega is clocked @ 1600MHz out of the box, I will eat my shoe on Twitch.tv.
Originally Posted by Juicin View Post
Not in games, which is what 99.9999 percent of us care about
And unless you own a business, you get paid for your time. So your compute power just makes more work for you not less
Ryzen is a joke to the vast majority of the market who would consider buying their product.
sugarhell is offline
post #506 of 745 Old 12-09-2012, 06:57 PM
BababooeyHTJ's Avatar
Quoted: 0 Post(s)
Liked: 197
They do it to keep tdp down. I think that 1100mhz is a reasonable expectation on air. With a good cooler you can expect 1200mhz+.
Not really, the highest oc that I know of is Sapphire's 950mhz oc edition. I'm pretty sure that AMD must not allow more than that. I can't think of any other reason why someone hasn't released a card with an oc higher than the boost bios.
BababooeyHTJ is offline
post #507 of 745 Old 12-09-2012, 07:08 PM
sugarhell's Avatar
Quoted: 3 Post(s)
Liked: 565
7970 matrix come with 1100 mhz core lock.
post #508 of 745 Old 12-09-2012, 07:09 PM
Quoted: 0 Post(s)
Liked: 197
I had assumed that you were talking about 7950. Its late.
post #509 of 745 Old 12-09-2012, 07:11 PM
Raptorpowa's Avatar
Quoted: 0 Post(s)
Liked: 14
Originally Posted by Dimaggio1103 View Post
that's like one bench, could you show some in game benches? or unigin heaven?
lol still scratching..this guy just don't give up....go look at tsm106 benches, I think he has them tongue.gif
Raptorpowa is offline
post #510 of 745 Old 12-09-2012, 07:15 PM
sugarhell's Avatar
Quoted: 3 Post(s)
Liked: 565
Just point out that companies give more love to the top model:p 7950 is underclock first to keep distance from 7970 and second to keep low the power consumption. But if you release your product after 8 months you can adjust it better to competition. biggrin.gif
Closed Thread
