[Tech4Gamers] AMD Radeon RX 460 for $99 and the Radeon RX 470 for $149 - Page 40 - Overclock.net
post #391 of 470 Old 08-10-2016, 12:17 PM
AmericanLoco's Avatar
Quoted: 0 Post(s)
Liked: 110
Do you have a link?
AmericanLoco is online now
post #392 of 470 Old 08-10-2016, 01:13 PM
Apple Enthusiast
EightDee8D's Avatar
Quoted: 0 Post(s)
Liked: 184
Originally Posted by AmericanLoco View Post
Do you have a link?
http://techreport.com/review/30413/nvidia-geforce-gtx-1070-graphics-card-reviewed/4
http://techreport.com/review/30328/amd-radeon-rx-480-graphics-card-reviewed/5
980 - 66% vs 480 36%
1070 - 154% vs FURYx 16% more DCC bandwidth. (for some reason this chart shows 980 has 139% more dcc bandwidth)
So it's obvious that AMD's DCC algorithms aren't that efficient compared to nvidia. thus they require more raw bandwidth.
Cyro999 likes this.
"if (c->x86_vendor != X86_VENDOR_AMD)
setup_force_cpu_bug(X86_BUG_CPU_INSECURE);"
EightDee8D is online now
post #393 of 470 Old 08-10-2016, 01:26 PM
Overclocker
ku4eto's Avatar
Quoted: 0 Post(s)
Liked: 109
Really, those 100$ are total crap. The RX 480 (Sapphire model), costs here 380 levs, which is around 220$. TWICE AS MUCH. A RX 470 costs 480 levs - 280$. RX 480 - 600 levs - 350$. The GTX 1060 costs the same arm and leg (reference model). A used R9 280X costs ~180-200$.
Avatar from the manga : GATE - Thus the JSDF Fought There!
Can be found on Bato.to website.
Previous Hardware:Warning: Spoiler! (Click to show)
CPU:
Intel Pentium 2 400 @400Mhz, AMD Athlon Orion 1000 @1Ghz, AMD Athlon Thunderbird 1000B @1Ghz, AMD Athlon 64 LE-1640 Orleans @2.6Ghz, OC to 2.9Ghz, AMD Athlon 64 X2 5050e Brisbane @2.6Ghz OC to 2.9Ghz, AMD Phenom II 960T @3.6Ghz 1605T 2.8Ghz CPU-NB
GPU:
Voodoo 3, GeForce2 MX 400, GeForce4 MX 440, Inno3D 7300GT 256MB AGP8X, Sapphire Radeon X550 256MB PCI-Ex16, PowerColor Radeon HD6950 1GB
Monitors:
Belinea 17" CRT, KTC 17" CRT, HP 19" Office monitor.
ku4eto is offline
post #394 of 470 Old 08-10-2016, 01:39 PM
sinholueiro's Avatar
Quoted: 0 Post(s)
Liked: 9
The RX480 gets more powerful compared to GM204 as resolution increases, so it has to be a stronger memory bandwith. That cases TheTechReport shows are fully compressed and an uncompressed one, so are the best and the worst case. The median case has to be better in average to 8Ghz Polaris than a GM204.
sinholueiro is offline
post #395 of 470 Old 08-10-2016, 02:13 PM
ZealotKi11er's Avatar
Quoted: 6 Post(s)
Liked: 1787
What the hell is a black texture?
CPU History (Click to show)
CPU -> Sempron 2400+, Athlon 64 3700+, Core 2 Q6600, A8-3870K, Core 2 Q9550, Core 2 QX9770, Core i7 920, Core i5 2500K, Core i5 3570K, Phenom II X4 955, Core i7 3770K.
GPU History (Click to show)
FX 5200 128MB, 9800 Pro 128MB, 6800GS 256MB, 7600GT 256MB, HD 4850 512MB, HD 4870 1GB, 2x HD 4870 1GB, GTX280 1GB, HD 5850 1GB, GTX470 1.25GB, GTX580 1.5GB, HD 6950 2GB, HD 6950 2GB + HD 6970 2GB, HD 6990 2GB, HD 7970 3GB, 2 x HD 7970 3GB,R9 290 4GB, R9 290X 4GB, R9 Fury X 4GB, GTX 1080 8GB, GTX1080 Ti 11GB
MB History (Click to show)
ECS KN1 Extreme -> ASUS P5Q-E -> GIGABYTE GA-X58A-UD7 -> GIGABYTE GA-Z68XP-UD4 -> GIGABYTE GA-Z77X-UD5H -> ASRock Z77E-ITX
ZealotKi11er is online now
post #396 of 470 Old 08-10-2016, 05:59 PM
Quoted: 0 Post(s)
Liked: 9
I think that they say it in the reviews. It's just that, a texture that is it completely black, so if it's made of one color, is fully compressible.
post #397 of 470 Old 08-10-2016, 07:23 PM
Quoted: 6 Post(s)
Liked: 1787
Are not games made of random textures? Does the Nvidia Rendering method benefit from these black textures?
post #398 of 470 Old 08-10-2016, 07:37 PM
Apple Enthusiast
EightDee8D's Avatar
Quoted: 0 Post(s)
Liked: 184
Black textures are compressible ( any solid color/one color texture for that matter) so you can use dcc and get more bandwidth( depends on algorithm), for random/multicolored textures, raw bandwidth matters since they cannot be compressed. that's what i get from it. correct me if i'm wrong.
post #399 of 470 Old 08-10-2016, 08:06 PM
Quoted: 4 Post(s)
Liked: 215
color compression works even with multi-colored textures.
black textures just simply guarantees you get the maximum possible compression to emphasize their DCC efficiency.
its called a benchmark for a reason.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is online now
post #400 of 470 Old 08-10-2016, 08:44 PM
Quoted: 6 Post(s)
Liked: 1787
So AMDs compression can still improve since even GCN4 compression is behind that of Maxwell. HBM2 will benefit AMD greatly.
