Soundcard --> active Subwoofer --> Passive speakers ... no sound ? - Overclock.net
post #1 of 7 Old 12-24-2011, 05:09 AM - Thread Starter
Overclocker
Djankie's Avatar
Quoted: 0 Post(s)
Liked: 14
Hi there,
I connected my active subwoofer to soundcard (RCA line in connection). On the subwoofer there is a powered output for (passive speakers). I made that connection with bare wire speakers.
There is coming sound out of the subwoofer, but there is no sound coming out of the speakers :S.
Subwoofer: Monitor Supreme Sub 201A
Souncard: Xonar STX essence
speakers: Alesis monitor one Mk2 (passive).
What I've tried:
1. Different passive monitor
2. Different speaker wire cable (2.5mm and 1.5 mm)
What I think what might be the problem:
1. Bare wire connection speaker might be not good, I think of buying a banana plug but not sure if its gonna help/
2. Subwoofer output connection are not OK.
Headphones: Beyerdynamics t1/dt990 pro /ath a-900/sennheiser HD25-II/ koss porta pro/ px100
Headamp: Meier Audio Concerto
Source:X-fi Titanium HD
Djankie is offline
post #2 of 7 Old 12-24-2011, 06:49 AM
- Sarcasm - Just One Of My Many Talents
Quoted: 0 Post(s)
Liked: 374
Originally Posted by Djankie View Post
Hi there,
What I've tried:
Looking at the manual for your sub, the Front/Rear left and right RCA output connections are not powered. If you look at the connection possibilities (Pages 26-29), of the owners manual... It shows that you need to feed the sub with a "speaker level" (amplified signal) input (to the connections marked "From receiver") in order to get output from the adjacent RCA's outs (marked "To speakers). Line level inputs will not produce sound out to passive speakers. The sub’s amplifier is only for the subwoofer driver (speaker).
This connection is typically used when you do not have an independent subwoofer channel from your source device. The subwoofer’s crossover will remove the lower frequencies (below the Xover set point), route them to the subwoofers amp, and then send the remaining high frequencies out to the front/rear speakers. Again, this is all done with a signal that has already been amplified (speaker level).
If you are connecting to a computer, unfortunately you do not have "speaker level" outputs for the front and rear speakers... only line level, which requires powered speakers (not passive). The only way to overcome this, to use your passive speakers, is to add an amplifier to the system as shown in the connection diagrams.
Djankie likes this.
xandypx is offline
post #3 of 7 Old 12-24-2011, 08:04 AM - Thread Starter
Overclocker
Djankie's Avatar
Quoted: 0 Post(s)
Liked: 14
Hmm... line level input is a "low-level" input, so they do no need to be amplified ?.  And "to speakers" is not a RCA. it is a speaker wire, which has a "High" level output, this means that the subwoofers amp will amplify the speakers isnt?
Djankie is offline
post #4 of 7 Old 12-24-2011, 08:09 AM - Thread Starter
Overclocker
Djankie's Avatar
Quoted: 0 Post(s)
Liked: 14
Hmm **** I get it now. So in order to get this thing to work is:
soundcard --> receiver --> subwoofer --> speakers
The connection subwoofer --> speakers will only work if there is indeed a receiver/amp in the sub.
Am I right ?
Djankie is offline
post #5 of 7 Old 12-24-2011, 08:18 AM
4.0 GHz
Archngamin's Avatar
Quoted: 0 Post(s)
Liked: 58
If you want something cheap that will solve your problems > http://www.parts-express.com/pe/showdetl.cfm?Partnumber=310-300
Soundcard>Miniamp>Sub>Speakers
Archngamin is offline
post #6 of 7 Old 12-24-2011, 08:22 AM - Thread Starter
Overclocker
Djankie's Avatar
Quoted: 0 Post(s)
Liked: 14
Nice find! something similar in europe? :D
Djankie is offline
post #7 of 7 Old 12-25-2011, 11:25 AM
4.0 GHz
Archngamin's Avatar
Quoted: 0 Post(s)
Liked: 58
http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Tripath+TA2020&x=0&y=0
Closest thing I can find. I don't know what sites people in Netherlands use to buy things so just do a search of Tripath TA2020 or simply search mini amp.
Djankie likes this.
