Calculating Impedance of "Multi-way" Speakers. - Overclock.net
post #1 of 9 Old 09-16-2013, 03:26 PM - Thread Starter
Truedeal's Avatar
Quoted: 0 Post(s)
Liked: 32
How does one calculate the impedance of a two way speaker properly, or 3 way, 4 way etc?
I need this information because I want to create a simple first order high pass filter for two "midranges" and I would like to have correct resistance and capacitance values for my crossover components.
Say for example that the drivers that I am using are 4 ohm, 8 ohm and 8 ohm.
Two opposing things can create all things when working together.
post-flame-small.gifpost-flame-small.gifThe Windows 10 Club post-flame-small.gifpost-flame-small.gif
Waiting on my MB to blow up so that I have an excuse for a better one!
Truedeal is offline
post #2 of 9 Old 09-16-2013, 07:22 PM
Hi!
billbartuska's Avatar
Quoted: 0 Post(s)
Liked: 1249
While a simple resistor/capacitor crossover will work (been there/done that), for just a little more money you can build something that will sound good.
Truedeal likes this.
Misinformation is available from a variety of other sources. Misinformation is just like real information but wrong.
...and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 9 Old 09-17-2013, 04:09 PM - Thread Starter
Truedeal's Avatar
Quoted: 0 Post(s)
Liked: 32
What did you have in mind for something better?
Truedeal is offline
post #4 of 9 Old 09-18-2013, 06:34 AM
Hi!
Quoted: 0 Post(s)
Liked: 1249
The possibilities are pretty much endless.
What SQ do you require, what functionality so you require, and $$$?
Ohms Law
This
post #5 of 9 Old 09-18-2013, 08:38 AM - Thread Starter
Truedeal's Avatar
Quoted: 0 Post(s)
Liked: 32
Well, to be honest this is more of a cheaper SPL project.
I'm building this simple 3 way speaker to replace my sisters horrid 2.0 "system" as she calls it. So it wont be too hard to accomplish.
I was only thinking of a 12db/oct Filter to keep it a little more efficient than 6db/oct
My project budget is just about 200 dollars.
I will likely use a 6.5 In 4oHm Drive for the lower end:
This - not likely
This
Or this
and Two 3 inch 8 Ohm drivers that I already have, most likely in parallel.
In a ported enclosure that will look rather silly. When I get home I will have pictures of my "sketch"
Truedeal is offline
post #6 of 9 Old 09-18-2013, 06:24 PM - Thread Starter
Truedeal's Avatar
Quoted: 0 Post(s)
Liked: 32
An array of a not so sq enclosure...
Truedeal is offline
post #7 of 9 Old 09-18-2013, 07:44 PM
Hi!
Quoted: 0 Post(s)
Liked: 1249
cool!
post #8 of 9 Old 09-19-2013, 09:56 AM
Commodore 64
kevmatic's Avatar
Quoted: 0 Post(s)
Liked: 66
If you're going to DIY the amplifier, I would bite the bullet and go bi-amp. You get a ton more power that way, and less crossover distortion.
One of these days, I'm going to do that...
kevmatic is offline
post #9 of 9 Old 09-22-2013, 01:38 AM
Totally Gone Fishing!
Quoted: 0 Post(s)
Liked: 451
Is that correct? I've learned a different formula for resistors in parallel - I'm trying to work out why it wouldn't apply to a speaker. 4 + 8 = 2.66 Ohm at the amp?
Darren9 is offline
