Replace Passive Subwoofer with a Powered Subwoofer - Overclock.net
post #1 of 11 Old 08-18-2016, 04:15 PM - Thread Starter
Intel Overclocker
xenkw0n's Avatar
Quoted: 0 Post(s)
Liked: 21
As the title states, I'm curious about if it's possible to replace a passive subwoofer with a self-powered one (built in amp) that not only gets connected to my receiver but also plugs into an outlet for power.
I own the Cambridge Soundworks DTT3500 and the subwoofer that came with it is most definitely powered by the receiver since it doesn't plug into the wall. It still works but the speakers themselves can get a lot louder than what I feel would be a respective appropriate bass level. The chords that come with it aren't the kind that simply plug in, I have to insert spliced ends into two 'pinching' mechanisms (mentioning this in case it plays a factor in what I can do... or maybe I could just buy a new chord?).
The setup looks as follows;
Is it possible? If so, any good options in the 12" range (willing to go any size honestly, room is not an issue)?
xenkw0n is online now
post #2 of 11 Old 08-18-2016, 09:32 PM
Hi!
billbartuska's Avatar
Quoted: 0 Post(s)
Liked: 1249
The subwoofer you have is passive. It is powered by the amplifier in the decoder.
You could replace it with a different unpowered sub. But that sub has to function with the existing 35 watt amplifier..
DTT3500 Digital 6-Channel Amplifier
Satellite speaker: 7 watts RMS per channel
Center Channer amplifier: 21 watts RMS per channel
Subwoofer amplifier: 35 watts RMS per channel
Misinformation is available from a variety of other sources. Misinformation is just like real information but wrong.
...and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 11 Old 08-18-2016, 10:15 PM - Thread Starter
Intel Overclocker
xenkw0n's Avatar
Quoted: 0 Post(s)
Liked: 21
So there's no way I could hook up a powered sub and just use the receiver for the signal because it would still try to send power and that would cause issues? I guess I'm SOL then because I doubt I'll find a 35 watt passive subwoofer that would sound much better. frown.gif
post #4 of 11 Old 08-18-2016, 10:57 PM
Hi!
Quoted: 0 Post(s)
Liked: 1249
That box has a sub woofer line level output.
You could send that to an amplifier that powers a new, unpowered sub.
xenkw0n likes this.
post #5 of 11 Old 08-19-2016, 05:19 AM - Thread Starter
Intel Overclocker
xenkw0n's Avatar
Quoted: 0 Post(s)
Liked: 21
Perfect, thank you!
post #6 of 11 Old 08-19-2016, 09:51 AM - Thread Starter
Intel Overclocker
xenkw0n's Avatar
Quoted: 0 Post(s)
Liked: 21
So just follow-up... This subwoofer seems to fall into a nice category for what I'm looking for;
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130
Then I could use this splitter from the Subwoofer Line Out (Might need a female to female in this instance, will have to look at the receiver later and figure out what kind of plug is in the back of it) http://www.monoprice.com/product?c_id=102&cp_id=10218&cs_id=1021803&p_id=663
And connect the sub from the splitter using these cables http://www.monoprice.com/product?c_id=102&cp_id=10218&cs_id=1021803&p_id=659
post #7 of 11 Old 08-19-2016, 11:12 AM
Hi!
Quoted: 0 Post(s)
Liked: 1249
Looks like all you need is a single RCA cable.
post #8 of 11 Old 08-19-2016, 12:31 PM - Thread Starter
Intel Overclocker
xenkw0n's Avatar
Quoted: 0 Post(s)
Liked: 21
Maybe I should stop thinking so much and just plug things in. Wow that would be very simple. This old sound system has done me well over the years and want to give it a little extra kick now that I have the space for a bigger sub. I just have to make sure whether I need a female or male end connector for my receiver and I'll be on my way.
post #9 of 11 Old 08-19-2016, 12:38 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 80
All you should need is a standard single RCA cable.. both the receiver and sub should be the female plugs, and just use a standard single RCA cable (male plugs on both ends)
BlkDrgn28 is offline
post #10 of 11 Old 08-19-2016, 01:05 PM - Thread Starter
Intel Overclocker
xenkw0n's Avatar
Quoted: 0 Post(s)
Liked: 21
I'm fairly certain the receiver doesn't use a standard male RCA connection. I'll check it out when I get home after the weekend and make sure what type of connector it uses.
