help me to reach 4.8Ghz (Asus P8Z68-V Pro/Gen3 + 2600k) with low vcore - Overclock.net
post #1 of 7 Old 12-15-2011, 11:38 AM - Thread Starter
visata's Avatar
Quoted: 0 Post(s)
Liked: 3
I recently assembled my new PC based on overclock.net user preferences, so I bought Asus P8Z68-V Pro/Gen3 + i7 2600k + H100 (p/p) + Haf X + HX750.
I'd like to overclock my system to 4.8Ghz with low vcore value. I followed the guide below and managed to keep my system stable at 4.8Ghz only with 1.425V.
http://hardforum.com/showthread.php?t=1578110
Are there any members with similar config, overclocked their CPU to 4.8Ghz and could provide their BIOS settings?
Thanks in advance
breenemeister likes this.
visata is offline
post #2 of 7 Old 12-15-2011, 11:55 AM
3.0ghz
breenemeister's Avatar
Quoted: 0 Post(s)
Liked: 56
Thanks in advance
Check the Stable Sandy link in my signature. Munaim1 is now posting BIOS templates there. Your chip may just not be a good overclocker as well. There's not really a secret to low vcore, either it works or doesn't. I've been through 3 2700ks to find one that suits me. However, I would think a current 2600K should be able to get 4.8 at lower vcore than you're showing.
BTW, welcome to OCN. Prepare to spend lots of time here, whether your mean to or not.thumb.gif +rep for your first post.
breenemeister is offline
post #3 of 7 Old 12-16-2011, 05:50 AM - Thread Starter
visata's Avatar
Quoted: 0 Post(s)
Liked: 3
Thanks for a reply.
I'm aware about Sandy Stable Club and spent much time reading posts there actually too much smile.gif
I did some more testing just by leaving everything on auto and only changing multiplier. Here are my results:
44x - max vcore value 1.336V
45x - 1.352V (diff 0.016)
46x - 1.392V (if I disable spread spectrum, it raises to 1.4V) (diff 0.4!)
So it seems it's not worth to overclock over 45x as vcore rises disproportionately unless I play around with manual settings.
I also found one user with similar hardware specs (expect he owns slightly different motherboard P8Z68-v Pro instead of GEN3) and tried using his BIOS settings but I ended up with 1.488v instead of advertised 1.312v. Maybe my chip is not good enough for extreme overclocking?
http://forums.overclockers.co.uk/showpost.php?p=20744550&postcount=12
visata is offline
post #4 of 7 Old 12-16-2011, 12:29 PM
3.0ghz
Quoted: 0 Post(s)
Liked: 56
Thanks for a reply.
I have the exact mobo as you and I've noticed that the board tends to inflate voltages more than is needed for most chips, kind of like throwing enough voltage at it for the worst case scenario. When I put mine on auto at 4.8 GHz with CPU current capability at 140%, it booted with the voltage at 1.544! All chips are different, but here's a direct link to all my pertinent BIOS settings for a 12 hours stable Prime 95 blend run at 4.8 GHz at the sandy stable thread. I'm using offset voltage of +.005, but I get the same results at manual 1.360. This may be a good starting point for you.
http://www.overclock.net/t/968053/official-the-sandy-stable-club-guides-voltages-temps-bios-templates-inc-spreadsheet/6110#post_15931225
post #5 of 7 Old 12-16-2011, 02:58 PM - Thread Starter
visata's Avatar
Quoted: 0 Post(s)
Liked: 3
Same here, when I changed CPU capability to 130% or 140%, I've got similar vcore results too. I found a good point here:
http://www.overclock.net/t/1183710/i7-2700k-5-0ghz-1-41v/30#post_15958950
If I disable HT, I believe I will get the same voltages as 2500k owners.
visata is offline
post #6 of 7 Old 12-16-2011, 03:40 PM
3.0ghz
Quoted: 0 Post(s)
Liked: 56
[/URL]
Yeah, but then you should have just bought a 2500K! Leave that HT enabled.thumb.gif
post #7 of 7 Old 12-16-2011, 05:26 PM
PC Gamer
Saizer's Avatar
Quoted: 0 Post(s)
Liked: 22
LOL, after reading this post I can call myself a lucky person: 4,5 Ghz with 1,25 of VCore xD. I think this also depends on the motherboard: You got a pretty basic motherboard (while I have a pretty nice EVGA P67 FTW, for instance), IMO.
Saizer is offline
