Complete Overclocking Guide: Sandy Bridge & Ivy Bridge | *ASRock Edition* - Page 795 - Overclock.net
View Poll Results: Was this guide helpful?
Yes (and I DO have an ASRock motherboard). 237 80.07%
Yes (but I DO NOT have an ASRock motherboard). 45 15.20%
No (and I DO have an ASRock motherboard). 7 2.36%
No (but I DO NOT have an ASRock motherboard). 7 2.36%
Voters: 296. You may not vote on this poll
post #7941 of 9601 Old 04-12-2014, 05:08 PM
No-Post
inedenimadam's Avatar
Quoted: 0 Post(s)
Liked: 469
Originally Posted by morbid_bean View Post
Hello,
Would this awesome guide work for Haswell?  I am using a 4670k on a Asrock z87 Extreme4 and having Hell of a hard time finding guides for this combination.
no. sorry. completely different.
It puts the shoe in its mouth or else it gets deleted again.
#solefood
inedenimadam is offline
post #7942 of 9601 Old 04-16-2014, 04:43 PM
M0reP0wer's Avatar
Quoted: 0 Post(s)
Liked: 2
If I go into system properties and under advanced > performance > settings > and then check off "Adjust for best performance" will this mess up the upshifting and downshifting of the multiplier for the speedstep tech?
I'm running win 7 btw.
M0reP0wer is offline
post #7943 of 9601 Old 04-16-2014, 10:30 PM
No-Post
Quoted: 0 Post(s)
Liked: 469
No, that will just disable some eye candy. You will still idle properly.
#solefood
post #7944 of 9601 Old 04-18-2014, 04:04 AM
bloodysummer's Avatar
Quoted: 0 Post(s)
Liked: 0
Hi!
Thanks for the Guide! Im tying to overclock my 3570k with this guide using my Asrock Z77 Extreme 4. I got a few questions regards this guide since im a bit confused.
With this section:
-Getting closer... (Click to hide)
Now we will be working with both CPU multiplier and Turbo Boost Voltage.
All settings should be set from the previous section.
Goal: Achieve the highest stable multiplier with Turbo Boost voltage increase.
TEST: Pass 5min of "The Prime Test".
PASS: Increase the CPU multiplier by 1.
FAIL: Increase the Turbo Boost by 1 spot.
FAIL (Max Vcore): Decrease the CPU multiplier by 1.
Repeat this until you achieve the GOAL. For a nice easy overclock, precede to the Final Test, otherwise go to the next section.
Starting off with an OFFSET of +0.005v and Turbo Boost of +0.004v.
It says that if it failed ill be bumping up the Turbo Boost, so that means increasing the +0.004v right? or increase offset +0.005v?
One more thing, while running Prime95, my CPU-Z has stopped working. Does it means my OC is not stable?
Thanks a LOT.
bloodysummer is offline
post #7945 of 9601 Old 04-18-2014, 05:07 AM
Quoted: 0 Post(s)
Liked: 0
Originally Posted by bloodysummer View Post
Hi!
With this section:
Thanks a LOT.
Ignore this question smile.gif I have done some back reading and got the answer to my question. Reading is really an essential biggrin.gif
post #7946 of 9601 Old 04-18-2014, 09:05 PM
No-Post
Quoted: 0 Post(s)
Liked: 469
Hi!
With this section:
Thanks a LOT.
LOL...well we are here if you get stuck again. Welcome to the forums!
#solefood
post #7947 of 9601 Old 04-19-2014, 02:04 AM
Quoted: 0 Post(s)
Liked: 0
Hello!
Here's my first try OC'ing my 3570k with my Asrock Z77 Extreme4
Any suggestions how to lower my voltages? Do i have to lower turbo v or the offset?
Turbo Boost: +0.004v
Offset: +0.005v
LLC: Lvl 3
CPU PLL: 1.709v
VID: 1.3060v
CoreV: 1.288 Full load
0.840 Idle
Temps: Min Max
39c 79c
31c 83c
31c 77c
36c 76c
1hr w/ PrimeBlend
Im using a Swiftech H320 (push/pull) cooler, its way too hot here in the Philippines right now since its summer time. I got this temps with AC on :/ and i think its kinda HIGH.
Thanks!
post #7948 of 9601 Old 04-19-2014, 08:25 AM
Intel Overclocker
Lucky 23's Avatar
Quoted: 0 Post(s)
Liked: 85
You can try using a negative offset to decrease your full load vcore but your idle vcore is already quite low so you may run into stability issues.
Rather then decrease the voltage, I would suggest leaving everything the same and increasing the multiplier to 45 +
Lucky 23 is offline
post #7949 of 9601 Old 04-19-2014, 11:07 AM
Quoted: 0 Post(s)
Liked: 0
Hello!
I tried giving it a x45 multi, from +0.004 up to +0.020v i got bsod, i stopped for now, and planning to continue it for tomorrow, anyways for the said turbo voltages, it gave me up to 1.30-1.31'sh full load voltage. How about my temps? are they good? or a bit high. Its really hot here in the phils now.
Thanks!
post #7950 of 9601 Old 04-19-2014, 04:51 PM
Intel Overclocker
Lucky 23's Avatar
Quoted: 0 Post(s)
Liked: 85
Temps are ok. You should be able to reach 4.5ghz without any issues. I would try to keep it under 90c when stressing the CPU on Prime 95.
Lucky 23 is offline
