Max safe temperature for E6600? - Overclock.net
post #1 of 27 Old 10-07-2006, 09:36 PM - Thread Starter
Commodore 64
androoj's Avatar
Quoted: 0 Post(s)
Liked: 0
What is the maximum safe temp for an E6600? I just got one with the Asus P5W DH Deluxe board. If it makes a difference, I have 2GB Corsair XMS at 4-4-4-12. I'm using the stock HSF and it seems to do very well. Here's what I've noticed so far (all temps in F):
No OC (2.4Ghz): Idle in the lower 70s, in the mid to high 80s under load.
10% OC (2.63Ghz): Idle mid to high 80s, upper 90s under load.
15% OC (2.75Ghz): Idle upper 90s, between 110 and 115 under load.
I haven't had any lockups, reboots, or anything strange yet. How much further am I likely to get without problems? This CPU seems to OC quite easily...
androoj is offline
post #2 of 27 Old 10-07-2006, 09:43 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 715
As long as the CPU is under 55C it should be fine. The E6600 can get up to 3.2 on air very easily. You can go up to 3.6 or higher with high quality air/water or phase.
JacKz5o is offline
post #3 of 27 Old 10-07-2006, 09:52 PM
The Pook's Avatar
Quoted: 0 Post(s)
Liked: 919
Uh, 55C is more than fine for a C2D.
Under 85C using TAT. It measures temps differently than other programs, is the only one ATM that shows the right temp. The temp sensor is in a different place, closer to the die.
The Pook is online now
post #4 of 27 Old 10-07-2006, 09:57 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 715
Ohh yeah lol for the C2D the TAT is fine if its around 85C because its the temp of the actual core, not the sensor next to it
JacKz5o is offline
post #5 of 27 Old 10-08-2006, 07:45 AM - Thread Starter
Commodore 64
androoj's Avatar
Quoted: 0 Post(s)
Liked: 0
Ok maybe this is a retarded question but are you sure 85C is safe? That seems terribly hot. I'm shocked that they release this at the lower speeds if they could have pushed them much harder. I could probably go over by 1G before getting that hot.
androoj is offline
post #6 of 27 Old 10-08-2006, 07:47 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 58
yep the smaller the die is the more heat they can take i belive but mine runs at load 74c and nothign bad i think 85 is the max
swayne is offline
post #7 of 27 Old 10-08-2006, 07:48 AM
Forum Manager
Quoted: 4 Post(s)
Liked: 1329
No 85c for a core Temp isnt acceptable really i would keep it alot cooler than that when possible.
Welcome to Overclock
ENTERPRISE is offline
post #8 of 27 Old 10-08-2006, 07:48 AM
Commodore 64
MindOfChaos's Avatar
Quoted: 0 Post(s)
Liked: 14
85 C does seem really hot.
MindOfChaos is offline
post #9 of 27 Old 10-08-2006, 07:48 AM
4.0ghz
bicolormoth's Avatar
Quoted: 0 Post(s)
Liked: 21
can somebody link to somewhere that says 85C is the max safe??
i've looked on the intel but couldnt find anything
Mikes Rig : Allendale 6300 / Gigabyte ds4 / 2Gb DDR2 800Mhz Ram G-skill / X1900GT / Hiperpower 530w / Coolermaster Centron
My other rig for Grandad : 2.8Ghz Celeron D / Asrock P4i65G / 512mb pc3200 / 20gb HDD / Acer cd-rom + Fdd / 400w PSU / really small ugly case.
bicolormoth is offline
post #10 of 27 Old 10-08-2006, 07:49 AM
4.0ghz
Nasgul's Avatar
Quoted: 0 Post(s)
Liked: 670
What motherboard and video card you have? Is the case a mid-tower?
Also, if possible, see if you can buy a Thermaltake Big Typhoon and some Artic Silver 5 paste, that is the best way to go with an E6600, stock HSFs are horrible.
Nasgul is offline
