i5 3570k, hyper 212 evo, temps out the roof - Page 2 - Overclock.net
post #11 of 14 Old 08-22-2012, 07:29 AM
MrHyde's Avatar
Quoted: 0 Post(s)
Liked: 5
I've got a 3570k overclocked to 4.4ghz. I use the CM212, as well as AS5. Idle temps are around 27c, gaming 50c, and P95 tops out at 76c.
I'm betting you've either got an airflow problem, or a seating issue. How many fans are you running? (Admittedly, you shouldn't be 90c+ with a stock system due to poor air flow...honestly, it really sounds like a TIM application/Seating issue.)
MrHyde is offline
post #12 of 14 Old 08-22-2012, 07:54 AM
Queesy's Avatar
Quoted: 0 Post(s)
Liked: 1
Thats super high. My average temps is 65-70C on prime95.
Running at 4.2 GHz 1.180v-1.190v.
I'm using the CM 212+. I had to reseat the heatsink once because the first time I had some residue that spilled over (didn't touch the pins).
The method I use is I put less than a grain size on the cpu. Really, its a TINY amount. I then use a plastic bag and smear it evenly, coating the entire cpu with a thin layer.
I then squeeze two lines (moderate amounts, but not a lot either) onto the copper heat pipes on the CM 212+ heat sink. I then mount it and screw it and all that jazz.
My average temps on idle is 30-34C, but it drops to the mid 20's if I turn on my AC biggrin.gif.
My max temps I see not on Prime is 50C-55C.
I might increase my multiplier in the future just for fun.
Queesy is offline
post #13 of 14 Old 08-23-2012, 01:39 AM
4.0 GHz
lordj's Avatar
Quoted: 0 Post(s)
Liked: 20
You don't need to smear it manually - you can just put the heatsink on and the weight of it will spread it easily and evenly, but well, everyone has different ways biggrin.gif
lordj is offline
post #14 of 14 Old 09-20-2012, 10:04 PM
ashar31's Avatar
Quoted: 0 Post(s)
Liked: 0
I have a 3570k and the idle temps i get are about 25-29 (no A.C). When im just browsing and navigating windows its about 30-35 and with p95 the max reached was 65. I'm overall happy with the performance so thumb.gif.
ashar31 is offline
