which setting is better? - Overclock.net
post #1 of 5 Old 11-29-2006, 09:22 PM - Thread Starter
Commodore 64
knightsthatsaynee's Avatar
Quoted: 0 Post(s)
Liked: 0
OCing a E6600 with stock cooling and P5B Del...aftermarket cooler for Christmas
1. 333 X 9 = 2.97 1.3875 Vcore DDR2 666 65C dual Prime95 4hrs
2. 425 X 7 = 2.97 1.35 Vcore DDR2 850 64C
Normal heat load with Photoshop is 51C
Is this heat about average for OC'd 6600 with stock fan/HS?
#1 or #2 better?
knightsthatsaynee is offline
post #2 of 5 Old 11-29-2006, 09:27 PM
1.3ghz
The Argosy's Avatar
Quoted: 0 Post(s)
Liked: 11
1. Why is #1 vcore more than #2?
2. It takes something like orthos to test for stability
3. #2 is better because your RAM is going faster
The Argosy is offline
post #3 of 5 Old 11-29-2006, 10:06 PM - Thread Starter
Commodore 64
Quoted: 0 Post(s)
Liked: 0
1. I would like to know....It wouldn't pass Prime95 any lower
2. Isn't Prime95 a good alternative?
3. That's what I thought Sisoft Sandra reports Dhrystone and Whetstone are faster with 333x9, but most everything else is faster with 425X7
post #4 of 5 Old 11-29-2006, 10:32 PM
1.3ghz
The Argosy's Avatar
Quoted: 0 Post(s)
Liked: 11
orthos is a way to run 2 threads of prime to test dual-core CPUs
your #1 example is a lower FSB, which is why I was wondering about the difference
post #5 of 5 Old 11-29-2006, 11:07 PM - Thread Starter
Commodore 64
Quoted: 0 Post(s)
Liked: 0
I've never used orthos, but I understood that running 2 threads of Prime95 was the same as running 2 of orthos? I have it configured to run 1 on core0 and 1 on core1.
