[How To] Delid your Ivy Bridge CPU with out a Razor Blade! - Page 78 - Overclock.net
post #771 of 1399 Old 04-17-2013, 11:50 AM
Scott1541's Avatar
Quoted: 1 Post(s)
Liked: 65
Originally Posted by bobsaget541 View Post
Great guide! Will be doing this Friday or Saturday. What is recommended for cleaning the TIM off the die?
Alcohol is best, something like Methanol, Ethanol, Propanol (isopropyl alcohol) would be fine smile.gif
Camera Gear: Nikon D600, D7200, F60 & much more...
Steam: scott1541
Origin: Scott3933OCN Funnies... (Click to show)
"yawn. RMS is trolling again. Wake me when he returns to planet Earth"
"Staying inside doesn't get you mounting your telephoto on some F mount."
1 Million+ Folding at Home points  Chimp Challenge Participant
Scott1541 is offline
post #772 of 1399 Old 04-17-2013, 11:52 AM
justanoldman's Avatar
Quoted: 0 Post(s)
Liked: 282
Old credit card to remove the glue from the pcb and IHS, and isopropyl alcohol with q-tip cleans up the die very easily. Getting all the glue off took me more time than anything else in the process.
justanoldman is offline
post #773 of 1399 Old 04-17-2013, 11:54 AM - Thread Starter
WaterCooler
KuuFA's Avatar
Quoted: 0 Post(s)
Liked: 197
Yup got a quick video in the op about how to do it!
KuuFA is offline
post #774 of 1399 Old 04-17-2013, 06:20 PM
COOKIE
BonzaiTree's Avatar
Quoted: 0 Post(s)
Liked: 40
Oh, and try to find the highest percentage alcohol you can if you're going isopropyl.
I have 99% and it works great.
2009 WRX with 298awhp/304awtq
2016 WRX (Daily driver)
BonzaiTree is offline
post #775 of 1399 Old 04-17-2013, 11:24 PM
bobsaget541's Avatar
Quoted: 0 Post(s)
Liked: 0
Thanks!
Thanks again!
bobsaget541 is offline
post #776 of 1399 Old 04-18-2013, 01:15 PM
ztkraptor's Avatar
Quoted: 0 Post(s)
Liked: 1
Originally Posted by dealio View Post
oh wow... but a razor is 50 cents, a vise 50 bucks
Actually....that isn't a half bad idea...
What if you used extremely strong threaded nylon(spider wire) fishing line? and pulled it under and around?
ztkraptor is offline
post #777 of 1399 Old 04-18-2013, 01:21 PM
PC Gamer
Aparition's Avatar
Quoted: 0 Post(s)
Liked: 247
Funny... I thought about making a string saw myself to do this. Wire saws are extremely effective, but one made of nylon would be much safer to test on a CPU tongue.gif
http://www.youtube.com/watch?v=srz4DmPXxu8
Aparition is offline
post #778 of 1399 Old 04-18-2013, 01:22 PM
spoonium's Avatar
Quoted: 0 Post(s)
Liked: 11
I've actually investigated the usage of dental floss to cut through the adhesive, but at least for my chip it was nigh impossible to fit it in between the IHS and the die, so this was no option. On the other hand, I wasn't able to fit in a ceramic glass scratcher (or whatever they're called in English) there either, while others had great success using them.
spoonium is offline
post #779 of 1399 Old 04-18-2013, 02:52 PM
PC Gamer
Quoted: 0 Post(s)
Liked: 5
There is talk of freezing the CPU, which in turn freezes the adhesive, allowing the ability to possibly twist off the ihs
Qlix is offline
post #780 of 1399 Old 04-18-2013, 02:54 PM - Thread Starter
WaterCooler
KuuFA's Avatar
Quoted: 0 Post(s)
Liked: 197
I doubt it. It would require a lot of force to twist off the IHS. Considering we have a 100% success rate so far with this method I would think Freezing it would not allow you to break the Adhesive.
KuuFA is offline
