Haswell Overclocking Guide [With Statistics] - Page 806 - Overclock.net
post #8051 of 19652 Old 01-11-2014, 11:35 AM
Alxx's Avatar
Quoted: 0 Post(s)
Liked: 28
@logan
I would try clear Cmos.
Maybe its not the CPU but the Mobo that is somehow defect ?
I5 4670K 4,5@1,156, Gigabyte Z87X UD4H, 8GB Gskill Sniper 1866 Mhz, Sapphire Radeon 7950 Boost, 128 GB Samsung SSD 830, Samsung 1 TB HD, Scythe Mugen 2, Enermax Pro 525 W, Achieva Shimian 27 lite.
Alxx is offline
post #8052 of 19652 Old 01-11-2014, 11:45 AM
PC Gamer
jameyscott's Avatar
Quoted: 0 Post(s)
Liked: 227
Originally Posted by FtW 420 View Post
I was benching intel XTU on the 2600k pretty recently, not single core but gives an idea of the performance difference
5.5Ghz 2600k above Vs. 4.7Ghz 4670k below
I'm interested in single core performance for games that don't support the extra cores. That's why I'm asking. The difference should minimal from my 4770k at 4.7 and my SBe at 5.0, but I'm still interested.
jameyscott is offline
post #8053 of 19652 Old 01-11-2014, 11:57 AM
holyking's Avatar
Quoted: 0 Post(s)
Liked: 1
Nice information.
holyking is offline
post #8054 of 19652 Old 01-11-2014, 12:00 PM
Hhead's Avatar
Quoted: 0 Post(s)
Liked: 0
Does anybody have any idea about what this is??
i only see a blank page when i click manuel tuning in IETU
Hhead is offline
post #8055 of 19652 Old 01-11-2014, 12:02 PM
blaze2210's Avatar
Quoted: 1 Post(s)
Liked: 172
Wouldn't you be able to use CineBench to gauge the single-core performance of each chip, then compare the scores afterwards?
"I can explain it to you, but I can't understand it for you."
gftgy: "We're here to help, but you have to be willing to help yourself."
TwoCables: "I apologize for not simply giving you the answer you wanted, but if you give a man a fish, then you feed him for a day. However, if you teach a man how to fish, then you feed him for the rest of his life."
blaze2210 is online now
post #8056 of 19652 Old 01-11-2014, 12:10 PM
performance fanboy
FtW 420's Avatar
Quoted: 0 Post(s)
Liked: 213
This is about the closest thing I can think of, the superpi 32m 4ghz thread. The cpus are all at 4ghz, the differences in times are in the IPC & memory.
Not really the same as what differences there may be in single core gaming though, the 3930k shouldn't be too limiting. Memory clock & timing makes more difference in pi than it does in games.
http://www.overclock.net/t/1300766/super-pi-32m-4ghz-efficiency-challenge/0_50
____________________________
.:|Official|Volt|Mod|Squad|Member|:.
FtW 420 is offline
post #8057 of 19652 Old 01-11-2014, 01:29 PM
Intel Overclocker
eddward's Avatar
Quoted: 0 Post(s)
Liked: 0
Hi guys, did you notice that CPU-Z 1.68 finally shows real core voltage not only VID?
eddward is offline
post #8058 of 19652 Old 01-11-2014, 01:51 PM
Lance01's Avatar
Quoted: 0 Post(s)
Liked: 1
Username: Lance01
CPU Model: I4770K
Core Multiplier: 46
VCore: 1.3
Uncore Multiplier: 35
Uncore VOltage: Auto
Cooling Solution: H100I
Stability Test: Aida64 (1 Hour 21 minutes)
Batch Number
Ram Speed: 1333 9-9-9-24
Input Voltage: Auto
Motherboard - MSI Z87 G45 Gaming
I am having a sensor or program issue with my motherboard and was curious if anyone had a answer for the question below.
When I run Aida64 and HWinfo64 for a while the motherboard temperature go from being in the 30s and then it spikes up to 133 degrees Celsius where it becomes stuck on 133 and does not move. This does not cause any crashes but as soon as I restart into my bios it show the temperature stuck on 133 in the bios for the motherboard. If I make a change in the bios and restart it reverts back to normal until I start rerunning these tests. Any ideas on what I could do to solve this?
Lance
Fractal Arc Midi, AMD Ryzen 7 1800X, Noctua NH-D15, MSI X370 Carbon, 500GB Samsung 960 EVO M.2, 1 TB HDD, Corsair AX860, Corsair 2666, GTX 1080TI
Lance01 is offline
post #8059 of 19652 Old 01-11-2014, 01:55 PM
Commodore 64
Quoted: 0 Post(s)
Liked: 231
Originally Posted by bond32 View Post
Well I'm back to the drawing board... Going to get 47x stable with minimal vcore. Trying what you guys noted earlier about vccin being more vital than vcore so I'll see how it goes.
Edit: Dumb question, but have any of you ever had issues with CPUID HWMonitor? Has it caused issues keeping it open I mean...
I had issues with GPU_Z crashing running benchmarks when it was open .... and not crashing while closed.....so I been wary since.
JackNaylorPE is offline
post #8060 of 19652 Old 01-11-2014, 02:07 PM
WaterCooler
mandrix's Avatar
Quoted: 0 Post(s)
Liked: 170
Originally Posted by eddward View Post
Hi guys, did you notice that CPU-Z 1.68 finally shows real core voltage not only VID? Warning: Spoiler! (Click to show)
No joy for my Gigabyte...I still have to use 1.64 or HWINFO. Warning: Spoiler! (Click to show)
Maximus VIII Hero/6700K delidded w/CLP @ 4.8/Corsair LPX 4x4GB 2666 OC'd @ 3200/PCS 390X w/EK blockMain Rig specs (Click to show)
White Case Labs SM8 w/dual pedestals-Custom top extension
Rigid acrylic tubing/Dual D5's-MCP35x2
3x480mm-1x240mm Radiators
All psu wiring & sleeving by myself
2xAquaero 5 Pro's w/c - 1xFC8 for light panel & various led's
PowerColor PCS 390X w/EK block
6700K/Maximus VIII Hero/Corsair 4x4GB RAM
Build Logs (Click to show)Validations (Click to show)
mandrix is offline
