Skylake Overclocking Guide [With Statistics] - Page 864 - Overclock.net
post #8631 of 11372 Old 08-24-2016, 10:25 AM
v1ral's Avatar
Quoted: 0 Post(s)
Liked: 67
Quick question..
When testing an overclock, should i disable all power saving features or just have them enable?
I passed an over night of x264 max temps are below 80
4700mhz 1.35 bios LLC 5
4100mhz cache
2400 16 cas 16Gb
v1ral is offline
post #8632 of 11372 Old 08-24-2016, 10:41 AM
Cornerer's Avatar
Quoted: 0 Post(s)
Liked: 2
Originally Posted by HOODedDutchman View Post
Which version of prime95 ?
27.7/27.9 whatever, I know still slightly cooler than 28.X but don't care anymore since I concluded P95 not serving meaningful purposes.
P.S. was running 4.68GHz back then instead of my current 4.78 which might'd made few more deg differences.
Palit GTX 1080 JetStream [2126MHz core / 10854MHz memory]
i5-6600K+Hyper 212X [4.78GHz core / 4.27GHz cache]
2X8GB Hyper X Fury 2400 [2545MHz 15-16-16-30-401-1T]
ATX Gigabyte Z170-D3H (Crazy VDroop+Poor LLCs, NOT recommended)
SSD: Crucial BX200 480GB
HDD: Toshiba's crappy 2TB
Case Fans: Cosair ML120s/ML140s (Quieter/Higher Pressure than even Noctuas)
Case: SilverStone RL05BR (not recommended, poor motherboard screw-hole alignments)
Cornerer is offline
post #8633 of 11372 Old 08-24-2016, 10:49 AM
HOODedDutchman's Avatar
Quoted: 0 Post(s)
Liked: 12
Good temps for a cheap ass cooler. Must be because its an i5.
HOODedDutchman is offline
post #8634 of 11372 Old 08-24-2016, 01:52 PM
WaterCooler
mandrix's Avatar
Quoted: 0 Post(s)
Liked: 170
Razer blade method is so dumb. Find someone with a vice. Theres like zero dead cpu from vice method while blade method there are many.
Maybe....but have you delidded a Skylake cpu? The pcb is pretty thin. In the vice you can watch it start to bend. I did some pre-emptive cuts with a razor and returned the cpu to the vice and eased off the IHS without further bending.
But then, I've delidded 5 cpu's and know what my skill level is.
Maximus VIII Hero/6700K delidded w/CLP @ 4.8/Corsair LPX 4x4GB 2666 OC'd @ 3200/PCS 390X w/EK blockMain Rig specs (Click to show)
White Case Labs SM8 w/dual pedestals-Custom top extension
Rigid acrylic tubing/Dual D5's-MCP35x2
3x480mm-1x240mm Radiators
All psu wiring & sleeving by myself
2xAquaero 5 Pro's w/c - 1xFC8 for light panel & various led's
PowerColor PCS 390X w/EK block
6700K/Maximus VIII Hero/Corsair 4x4GB RAM
Build Logs (Click to show)Validations (Click to show)
mandrix is offline
post #8635 of 11372 Old 08-24-2016, 02:01 PM
Quoted: 0 Post(s)
Liked: 12
Ive delidded 2 or 3 ivy and a haswell. I didnt notice the pcb was any thinner then the other gens. Should be hitting straight from the end anyways. Should be no bending cuz should be no angled force on the pcb in the vice. I will check it out next time i have my heatsink off. Not gonna bother delidding mine cuz it wont achieve anything. I wont even gain 100mhz because I am at both the heat limit and voltage limit I am comfortable with already.
post #8636 of 11372 Old 08-24-2016, 02:05 PM
WaterCooler
mandrix's Avatar
Quoted: 0 Post(s)
Liked: 170
Oh, it's thinner all right. smile.gif I didn't see any bending with the previous generation cpu's either, but this one seemed to warrant a little more care. Either way, a few cuts with the razor helped to ease off the IHS with less force. But I understand why someone would not want to take a chance.
mandrix is offline
post #8637 of 11372 Old 08-24-2016, 02:45 PM
Quoted: 0 Post(s)
Liked: 12
I would definately be doing mine if it would give me any improvement. I am already at 1.36v tho for 4.6 and I don't want to go over 1.4v so even if i delidded I would prob be over that. Even if I wasn't delidding isnt worth 100mhz.
post #8638 of 11372 Old 08-24-2016, 02:54 PM
2.4ghz
Quoted: 0 Post(s)
Liked: 33
Are you delidded ?
Yes, Conductonaut on the die, Kryonaut on the waterblock
In no way should it be misconstrued that I do not disagree.
Arctucas is offline
post #8639 of 11372 Old 08-24-2016, 02:55 PM
2.4ghz
Quoted: 0 Post(s)
Liked: 33
Originally Posted by Mr.N00bLaR View Post
Im delidded and can stay at 82c @ 1.465v with my NH-D15. Crazy stuff smile.gif Props to silicon lottery biggrin.gif
At what frequency?
Arctucas is offline
post #8640 of 11372 Old 08-24-2016, 02:59 PM
2.4ghz
Quoted: 0 Post(s)
Liked: 33
With regard to de-lidding; maybe I am just afraid to trash a $350 CPU, but $30 (plus shipping, of course) for the Rockit 88 kit was well worth it, especially since it has the re-lidding tool which allows precise alignment to re-seal the IHS.
But that is just my opinion...
Arctucas is offline
