need help overclocking my liquid cooled xeon w3565 - Overclock.net
post #1 of 6 Old 06-14-2016, 09:28 PM - Thread Starter
kaitlin4599's Avatar
Quoted: 0 Post(s)
Liked: 2
ok so i have an HP Z400 desktop and im looking to overclock my xeon w3565 cpu its liquid cooled with a closed loop cpu cooler. obviously my bios has overclocking locked so what are my options and for those who ask its the same as an i7-960 and heres some links to overclocking results for my cpu
http://hwbot.org/hardware/processor/xeon_w3565/
HP Z400 workstation with a GTX 750Ti
kaitlin4599 is offline
post #2 of 6 Old 06-14-2016, 09:45 PM
Overclocker
MasterFire's Avatar
Quoted: 0 Post(s)
Liked: 84
Well if your BIOS has locked overclocking, you are out of luck? Since I would assume that means no changing the BCLK (and maybe the multiplier). So if that is not possible then I guess that is that.
You could see if there's similar motherboards from the same manufacturer that do have overclocking enabled and you could possibly flash your motherboards BIOS with a BIOS from one of these other motherboards. But I wouldn't hedge any bets on that working, not to mention if it doesn't, you end up with a borked BIOS and will have to replace it physically on the motherboard.
I'm old school... Because it was done right the first time.
MasterFire is offline
post #3 of 6 Old 06-14-2016, 10:06 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 2
are there any xeon or i7 boards that support my cpu and let me overclock
post #4 of 6 Old 06-14-2016, 10:15 PM
WaterCooler
Glends's Avatar
Quoted: 0 Post(s)
Liked: 10
Most of the Top X58 boards support them.
Glends is offline
post #5 of 6 Old 06-14-2016, 10:18 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 2
so im guessing i would just google x58 motherboard then buy one that is in my price range
post #6 of 6 Old 06-15-2016, 10:22 AM
Overclocker
MasterFire's Avatar
Quoted: 0 Post(s)
Liked: 84
It should yes, but if you want some certainty you could come back in here and ask.
