E4400 Overclock. NEED help - Page 2 - Overclock.net
post #11 of 14 Old 02-22-2008, 11:41 AM
333mhz
rice_tuner's Avatar
Quoted: 0 Post(s)
Liked: 2
allright...im noobish with this cause i just got this rig a while back..have'nt have had the time to OC it yet..
used a M2N-MX with an AMD 3000+ before that..
new to intel..so any article etc would be appreciated.
thank you guys.
rice_tuner is offline
post #12 of 14 Old 02-22-2008, 11:53 AM - Thread Starter
3.5ghz
Jeffmizrahi's Avatar
Quoted: 0 Post(s)
Liked: 44
Yeah i'm a noob also
It appears to be a high tech miniature kitty running at 4.0GHZ with possibly air cooling.
"Those who are poor, smile at what they have, yet those who have good fortune, frown at what they do not have."
Jeffmizrahi is offline
post #13 of 14 Old 02-22-2008, 12:47 PM
ericeod's Avatar
Quoted: 0 Post(s)
Liked: 2741
With the 650i chipset, just set the ram to unlinked and 800, That way you can OC the CPU without worrying about the ram beung OCed out oof specs.
As for the OC, you can probably keep the northbridge on default oltage, but you might need 1.3v when you start going past 1333 QDR (333 FSB). 1.4v should be good at around 1600 QDR.
As for the CPU, try upping the vcore maybe 1 or 2 notches at a 3.0GHz OC. the max you can run on the CPU is 1.5v, but that generates a lot of heat. So your cooling plays a vital role when OCing. Run CoreTemp to see what the VID is (default stock voltage for the CPU). That will give you a good basis to work with.
Benchmarking is so boring......
eVGA 680i Overclocking guide .......... ASUS P5E/Rampage Formula Thread.......... 4.4GHz CPU-Z
ericeod is offline
post #14 of 14 Old 02-22-2008, 04:58 PM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 44
Is 65 C to hot for a Core 2 duo e4400 i am running it at FSB of 1333. Under Orthos it goes to about 65C is that to hot?
