Help me Decide between Q6600 & E6750 - Page 3 - Overclock.net
post #21 of 32 Old 02-25-2008, 07:26 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 132
You may want to consider an aftermaket cooler for the Quad.
DuRoc is offline
post #22 of 32 Old 02-25-2008, 07:30 AM
ericeod's Avatar
Quoted: 0 Post(s)
Liked: 2741
I dont think he will have a problem with cooling if he sticks with the board listed. The 650i offers limited OCing. So he wont be running much, if at all over stock voltage. The board doesnt offer the proper GTL Ref voltage the Q6600 needs to OC much higher then 2.8Ghz, which should be possible with max of 1.3v vcore.
Benchmarking is so boring......
eVGA 680i Overclocking guide .......... ASUS P5E/Rampage Formula Thread.......... 4.4GHz CPU-Z
Chimp Challenge Participant  7 Million+ Folding at Home points  Overclock.net 10 Year Member
ericeod is offline
post #23 of 32 Old 02-25-2008, 07:35 AM
4.0ghz
jinja_ninja's Avatar
Quoted: 0 Post(s)
Liked: 131
Is there much performance advantage of having 2 x 8600GT? Selling both and getting a single 8800GT will be much more effective IMO.
jinja_ninja is offline
post #24 of 32 Old 02-25-2008, 07:38 AM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 16
Originally Posted by ericeod View Post
Just be aware that with the 650i chipset, you will most likely get a limmited 2.8GHz OC on the Q6600. You will have better luck with an updated version of the chipset found in the form of the 750i.
thx but i usally dont OC until ive had it for a year because theres no need for oc really quad LOL
Armend is offline
post #25 of 32 Old 02-25-2008, 07:39 AM
3.5ghz
edeekeos's Avatar
Quoted: 0 Post(s)
Liked: 38
650i ftl..
get a 680i LT atleast...
my buddy r4v3n runs his q6600 at 4ghz daily with air on a xfx 680i LT.
edeekeos is offline
post #26 of 32 Old 02-25-2008, 07:44 AM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 16
OKAY thx alot guys for helping me make the decision another day saved by OVERCLOCK.NET DA DA DA
Armend is offline
post #27 of 32 Old 02-25-2008, 07:59 AM
3.0ghz
zaccy001's Avatar
Quoted: 0 Post(s)
Liked: 15
Hey mate. I wouldnt even consider the E6750. You should have your sights on the E8400 Not only is it slightly faster but it runs cooler which yields higher overclocks. If your using air cooling then i would stray from using a quad as they just put out way too mutch heat. you wont even get near its overclocking potential using air cooling so its kinda a waste of money, however the E8400 will come close to maxing out under air, they just run so cool compared to the E6xxx series. Thats my opinion, hope you find it insightful.
I have a friend who, and please, I am not joking when I tell this, brought his computer to Best Buy Geek Squad to have them get rid of Spyware/Trojens. Three days later they called back, and said that it would be $700USD TO FIX BECAUSE THE SPYWARE HAD GOTTEN INTO THE MOTHERBOARD. That is, literally, verbatim. I didn't even know what to say.
zaccy001 is offline
post #28 of 32 Old 02-25-2008, 01:09 PM
1.3ghz
Galidan's Avatar
Quoted: 0 Post(s)
Liked: 13
I wouldn't bother SLI'ing the 8600GT. Just go for a single 9600GT or an 8800GT.
/Galidan
Galidan is offline
post #29 of 32 Old 02-25-2008, 01:20 PM
Back on the Air
losttsol's Avatar
Quoted: 0 Post(s)
Liked: 607
Originally Posted by kazakia View Post
1. instead of the Q6600 and the E6750 get the new E8400 penryn, cheaper better performance and OC'ing beast
2.Do not get 3GB ram just get 2 GB cause 3Gb of RAM cannot run in dual channel which will lower your performance. Most people do not ever use up thier 2GB unless in some crazy RAM intensive games.
I wouldn't call the E8400 an "OC'ing beast". It has been shown to be unreliable at 4.0GHz and higher. The Q6600 takes a higher percentage overclock much easier and is a proven chip.
losttsol is offline
post #30 of 32 Old 02-25-2008, 01:24 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 65
Quad > Dual.
I'd stay away from any card in the x6xx line, but that's my personal preference.
Manufacturing Consent is the Name of the Game
dankoni is offline
