Q6600 + 680i T2 PROBLEMS..HELP!! - Page 2 - Overclock.net
post #11 of 14 Old 02-26-2008, 06:04 PM
ericeod's Avatar
Quoted: 0 Post(s)
Liked: 2741
Originally Posted by Tricky View Post
Okay well, It seems like I've solved my problem. I raised the HT link, nForce, and PCI-E voltages.
Ht link: 1.45V
nForce: 1.625V
PCI-E: 1.4V
Havent crashed, its been a day now.
I have to Lap my TRUE 120, can anyone show me a guide? When I stress all 4 cores, the 2 highest cores reach 80C, that cant do good.
Thanks.
NVIDIA states that max votage for the 680i are:
Maximum Recommended Voltages
Note: Be very careful when increasing voltages as setting them too high can destroy
the processor and other components on the motherboard.
Below is a list of the safe, maximum voltages that should be used for overclocking.
Any voltages not mentioned are best left at their Auto setting.
q CPU Core: 1.58750v
q CPU FSB: 1.5v
q Memory: 2.3v edit: I wouldnt go over 2.2v without additional mosfet cooling
q nForce SPP: 1.50v
Here are the eVGA 680i T1 voltage settings, so which ones are you referring to?
Benchmarking is so boring......
eVGA 680i Overclocking guide .......... ASUS P5E/Rampage Formula Thread.......... 4.4GHz CPU-Z
Chimp Challenge Participant  7 Million+ Folding at Home points  Overclock.net 10 Year Member
ericeod is offline
post #12 of 14 Old 02-26-2008, 06:54 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 80
What BIOS version are you using?
There are ways of telling if BP is a witch. Does oil sink in water?
Xombie is offline
post #13 of 14 Old 02-26-2008, 07:04 PM - Thread Starter
Tricky's Avatar
Quoted: 0 Post(s)
Liked: 164
Latest, P32 i think. The one that makes Dual core penryns work.
Tricky is offline
post #14 of 14 Old 02-26-2008, 07:58 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 80
If you can't seem to get it stable (well it looks like you have already, but may want to try again under lower voltages), take a look at this thread.
http://www.evga.com/forums/tm.asp?m=...1&key=&#205193
Xombie is offline
