_₌= The Q9550 Club =₌_ [Please read first post] - Page 72 - Overclock.net
post #711 of 2408 Old 05-07-2009, 02:23 AM
Quoted: 0 Post(s)
Liked: 66
Can I join this club dudes!? I just got a q9550 E0 and it is running at 3.825ghz 1.368vcore, stable with linepack for 1 hour.
kurosu is offline
post #712 of 2408 Old 05-07-2009, 04:32 PM
3.0ghz
Quoted: 0 Post(s)
Liked: 57
hey have you triedtweaking the gtlref volts yet? cause i used to have my q9550 at 1.352v and thought that i needed that much vcore to stay stable. with the tweaking i did to the gtlref volts i was able to lower my vcore to 1.3v and pass 6+ hrs of occt. i'd also say to make sure your fsbv is about 1.3-1.4 and have the spp at 1.4-1.5. that way you can get the vcore down and have your chip live longer.
twisted_58 is offline
post #713 of 2408 Old 05-07-2009, 11:04 PM
733mhz
Quoted: 0 Post(s)
Liked: 4
Your chip will not die on you till your next upgrade, believe me...my cousin´s PC works with 1.365 for like 6 month....YOu will upgrade your chip way before your chip is dying...
blacklotusul is offline
post #714 of 2408 Old 05-07-2009, 11:23 PM
3.0ghz
Quoted: 0 Post(s)
Liked: 57
its just for the overall good of the chip since its 45nm. since all are different, chip A could run 24/7 with 1.36 for over a year but chip B could be at the same volts and die in like 6 or so months. plus overvolting can cause instabillity so its always good to find the lowest stable vcore for your overclock. and you also get the benefit of lower temps.
post #715 of 2408 Old 05-08-2009, 12:46 AM
Quoted: 0 Post(s)
Liked: 66
1.3625 is the max safe volts, and 1.45 is absolute max. Running it at 1.36 24/7 won't kill it. I think 1.4vcore is still safe for 24/7, but I would not go above that for 24/7.
So I wanted to ask about vtt, I have mine at 1.25 VTTvolts. It is also safe up to 1.4right? So up to 1.4 would be safe for 24/7? I have heard of high vtt killing chips man. I might try 1.35 for 4ghz, but not above that.
kurosu is offline
post #716 of 2408 Old 05-08-2009, 02:52 AM
733mhz
Quoted: 0 Post(s)
Liked: 4
I will not go over 1.36 for nothing in this World
post #717 of 2408 Old 05-08-2009, 05:14 AM
Intel Overclocker
shredzy's Avatar
Quoted: 0 Post(s)
Liked: 39
Would this CPU be a pretty decent upgrade from a E8400? Or should I go for the Q9650?
Can this CPU also hit around 4.5GHz on water without going over the MAX SAFE voltage? Which is?
shredzy is offline
post #718 of 2408 Old 05-08-2009, 05:33 AM
4.0ghz
Josh81's Avatar
Quoted: 0 Post(s)
Liked: 57
yeah and whats the point of degrading a chip and possibly killing it when you can use it in a backup rig..i gave my old e6600/8800 to my mom
Josh81 is offline
post #719 of 2408 Old 05-08-2009, 02:55 PM
3.0ghz
Quoted: 0 Post(s)
Liked: 57
that was my exact thinking. you can sell them, use them as a backup, or put them in a build for someone else. none of which can happen if the chip is dying or dead.
post #720 of 2408 Old 05-08-2009, 02:57 PM
3.0ghz
Quoted: 0 Post(s)
Liked: 57
i would say 1.4 is really the max vtt that you would want to run 24/7, on our board i know it maxes at 1.45. i'd say stay at 1.35 if you can. thats what mine is at i believe.
