Guide to Overclocking the Core I7 920 or 930 to 4.0ghz - Page 92 - Overclock.net
post #911 of 1477 Old 08-13-2010, 01:37 AM
1.3ghz
pdrider6890's Avatar
Quoted: 0 Post(s)
Liked: 5
Could you be crashing in the games because you are maxing your power supply??? Newer GPU's can suck up a lot more power, or is it possible the heat from your GPU is heating up the CPU or RAM causing them to fail?
pdrider6890 is offline
post #912 of 1477 Old 08-13-2010, 01:41 AM
WaterCooler
Nautilus's Avatar
Quoted: 0 Post(s)
Liked: 156
nice guide. subbed.
this is going to be very useful if i ever buy a i7 920 or 930.
Nautilus is offline
post #913 of 1477 Old 08-13-2010, 02:27 AM
733mhz
gobbo353's Avatar
Quoted: 0 Post(s)
Liked: 11
Actually to iNZoW
Besides the above, I'd raise my PCIE to 103, ICH to 1.24 and IOH/ICH I/O Voltage 1.54 or1.58
Have you tested your system with 3DMark Vantage or 06..? This will test your system similarly as to when playing BFBC2 for example, as Prime etc doesn't ones GPU/CPU/MEM concurrently..
It could be driver related also.. FOr instance i've reverted to CCC 10.5 hotfix as with more recent versions my FPS dropped by half and i was getting random crashes to desktop.
gobbo353 is offline
post #914 of 1477 Old 08-13-2010, 09:21 AM
Commodore 64
r80x's Avatar
Quoted: 0 Post(s)
Liked: 0
I'm currently at 3.8 and making stability tests in prime. I'm having a hard time getting it stabil and have to up the vcore all the time, currently at 1.216.
I would really want to get to around 3.8-4.0 with as low vcore as possible so that i have low temps and just a nice clock. I dont need a +4.0 just somewhere around 4.0.
My Bios is BLCK 181
ratio 21
Vcore 1.216
Speedstep disabled
turbo disabled
Dram DDR3 1451
Timing 8-8-8-24
DDR Bus voltage 1.66
Load Line Calibration enabled
PCIE 100
CPU and PCIE spread spectrum are disabled.
All other voltage setting and stuff are on AUTO because im not sure what to set them to.
Anyone have some advise on what settings to use for 3.8-4.0 with low vcore?
r80x is offline
post #915 of 1477 Old 08-13-2010, 10:59 AM
1.3ghz
Quoted: 0 Post(s)
Liked: 5
My Bios is BLCK 181
ratio 21
Vcore 1.216
Speedstep disabled
turbo disabled
Dram DDR3 1451
Timing 8-8-8-24
PCIE 100
Up the Vcore a little bit, or stay where you are at if you are unwilling to do so...
post #916 of 1477 Old 08-13-2010, 11:29 AM
4.0ghz
kneeki's Avatar
Quoted: 0 Post(s)
Liked: 38
My Bios is BLCK 181
ratio 21
Vcore 1.216
Speedstep disabled
turbo disabled
Dram DDR3 1451
Timing 8-8-8-24
PCIE 100
What is your VTT and QPI voltage?
kneeki is offline
post #917 of 1477 Old 08-13-2010, 12:34 PM
Commodore 64
r80x's Avatar
Quoted: 0 Post(s)
Liked: 0
They're on AUTO so i suspect that they are on default.
r80x is offline
post #918 of 1477 Old 08-13-2010, 05:17 PM
733mhz
gobbo353's Avatar
Quoted: 0 Post(s)
Liked: 11
My Bios is BLCK 181
ratio 21
Vcore 1.216
Speedstep disabled
turbo disabled
Dram DDR3 1451
Timing 8-8-8-24
PCIE 100
G'Day..
Yes up your Vcore to 1.25 or 1.28.. It's not uncommon to require 1.28 LLC1 to hit 3.8-4g so just go with the flow..
Otherwise or in any event if you would add your system specs to your sig it would make analysis easier and much more reliable..
gobbo353 is offline
post #919 of 1477 Old 08-14-2010, 12:37 AM
1.3ghz
FrozenW's Avatar
Quoted: 0 Post(s)
Liked: 19
Send a message via MSN to FrozenW Send a message via Skype™ to FrozenW
FrozenW is offline
post #920 of 1477 Old 08-14-2010, 04:26 AM
333mhz
M_T_M's Avatar
Quoted: 0 Post(s)
Liked: 0
I have motherboard EVGA Classified X58 and cpu i7 920. Now I want to know what the settings should be changed to stable for 4.0ghz? What voltage should be raised? Please help
M_T_M is offline
