1st overclock~need your help :) - Page 2 - Overclock.net
post #11 of 17 Old 02-09-2010, 06:31 PM
Commodore 64
bigdaddy88442's Avatar
Quoted: 0 Post(s)
Liked: 0
i have the same cpu and mobo and did what klote2314 suggested and nothing! could use some help
bigdaddy88442 is offline
post #12 of 17 Old 02-09-2010, 07:04 PM
Windows Wrangler
webguru1985's Avatar
Quoted: 0 Post(s)
Liked: 9
Originally Posted by klote2314 View Post
the Q6600 runs stable with Vcore 1.125 FSB 333 if its not just put it a little higher like 1.15
all u need is the stock cooler its good enough to handle it
this is what you are going to have to do
go to your BIOS go to AI Tweaker and put AI overclock Tuner on Manuel
then put the FSB at 333
and the Vcore (CPU voltage) at 1.125 ore 1.5 depends if it will run stable
then go to the advanced tab and go to cpu configuration and Dissable C1E ore CE1 dunno what its called something like that
and your all set
Nice case
webguru1985 is offline
post #13 of 17 Old 02-09-2010, 08:03 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 46
what's the max FSB that your motherboard can handle with RAM ???
this point is necessary for you to know, because when you increase your CPU FSB, this leads to increasing the RAM FSB too, and since this... you should keep an eye on the max FSB of memory that your motherboard can handle, once your RAM overclocks past the max allowed FSB setting in your motherboard (as a result of increasing the FSP of the processor) you will start facing instability issues, and my be the issues you are facing now were because of this ???
check out your RAM FSB, and see if you need to lower them in the bios to whatever your mobo can handle.
good luck.
the magical me is offline
post #14 of 17 Old 02-09-2010, 08:56 PM
Commodore 64
Quoted: 0 Post(s)
Liked: 0
well i am kind of new at this so i am not sure. i have the asus p5kc mobo and CORSAIR XMS3 4GB (2 x 2GB) DDR3 1333...i want to say 533??
post #15 of 17 Old 02-10-2010, 10:40 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 46
ummm... after reviewing your motherboard on the net, I could know some cons and pros of it, and some of the cons are that this motherboard runs somehow hot even at stock settings, and this may lead to some problems, and it does has some memory issues as I read, and some of the cool features it has is that it's combo memory support between DDR2 and DDR3 .
- regarding your issue with your overclocking... your motherboard supports DDR3 memory @ NATIVE speed of 1333 FSB, so I think it must support 1600 overclockability ( but I am not sure, you have to check out this with your motherboard manual), so if it supports 1600 FSB RAM overclocking, then you have got to make sure that your RAM doesn't exceed that number as a result of overclocking the processor, and if it doesn't even support memory overclocking, then you must keep it at its default speed to keep stable, and in such case I recommend you to lower the RAM FSB in advance before overclocking the CPU, that it will still be in the safe margin, and always monitor that your self.
best wishes.
post #16 of 17 Old 02-10-2010, 06:02 PM
Commodore 64
Quoted: 0 Post(s)
Liked: 0
ok well i got it to overclock but then it woulndt get past the post! i was thinking maybe i need to increase the voltage but i wasnt sure what a safe move would be? any thoughts
post #17 of 17 Old 02-10-2010, 09:32 PM
Commodore 64
Quoted: 0 Post(s)
Liked: 0
running at 3.3ghz 1.4875v temps under load around 50c and 38c idle
