First time overclocking, need help please. - Page 3 - Overclock.net
post #21 of 57 Old 04-29-2006, 12:46 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
What about the temperature thing in Speedfan and ASUS Probe II? I have one CPU temp in ASUS Probe II but I'm wondering is that for both cores of my Dual Core CPU? If so then I was looking in Speedfan at two different temps thinking they were each a core. I'll post a screenshot of my Speedfan to better explain myself.
Might have to click on the image to enlarge it.
I do hope that the one cpu temp from asus probe is the temp for both my cores, then I would be getting like 45-50C load and I could OC my CPU more.
potato is offline
post #22 of 57 Old 04-29-2006, 01:06 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 75
try downloading everest and seeing what your temp readout on there is:
http://www.download.com/Everest-Ulti...=uo&tag=button
and then get back to me on here once you see those temps, but im sure if your cpu isnt melting or anything and your computer hasnt shut down or any warnings have happened...theres no way it can be that hot, so its probably just an error or something, ive heard a lot of weird things about speedfan
suthernkid is offline
post #23 of 57 Old 04-29-2006, 01:12 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
Alright, I've come to the conclusion that both cores are the same temp so one CPU temp on all these programs is what it is. I feel kind of stupid now lol. Anyways, my CPU temp according to Everest is 35C, Motherboard is 32C. Going to see how high I can get my CPU now.
potato is offline
post #24 of 57 Old 04-29-2006, 01:20 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 75
im glad you know now!! now oc the hell out of your 820 i know its a great ocer
post #25 of 57 Old 04-29-2006, 01:23 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
So anything below 55C on load is alright? At 3.2GHz I've been running Prime95 for about 15 minutes and at load so far it's stabalized around 48. Will it get any hotter than that if I leave it run for about an hour you think?
potato is offline
post #26 of 57 Old 04-29-2006, 01:26 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 75
yeup it might but as long as your load temps arnt reaching 55-60c i think your definitely fine, and try to go as much up on stock vcore as you can because temps really wont increase much if the vcore hasnt raised
post #27 of 57 Old 04-29-2006, 01:30 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
up until now the vcore has been auto set, it's 1.28 now but I've noticed in cpu-z it raises and lowers a bit, would it be safe to lower it a bit more than that?
potato is offline
post #28 of 57 Old 04-29-2006, 01:37 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 75
well you could lower it, i think the lowest for 820s is 1.25 and all the way up to 1.4, so you could lower it and you might see a little bit of a temp drop because of the lowered vcore but usually if you want to oc you raise your vcore, so i think you should lower, then test and see if its stable and getting enough voltage seeing as its overclocked
post #29 of 57 Old 04-29-2006, 01:38 PM
Intel Overclocker
Quoted: 0 Post(s)
Liked: 234
wow, i took off the front of my case and my HDDs dropped 10 degrees.
What's next, banning mirrors because, oh no god forbid, if we see ourselves naked we're gunna be traumatized?
I'm like the inquirer, take everything i say with a grain of salt.
SLi Zone PSU listing- check to see if your PSU is SLi certified.
BF2 stats BF2142 stats
My Guide to BF2 Unlocks
cgrado is offline
post #30 of 57 Old 04-29-2006, 01:39 PM - Thread Starter
333mhz
Quoted: 0 Post(s)
Liked: 0
Alright, thanks for all the help!
potato is offline
