First build Need Help (New) - Overclock.net
post #1 of 5 Old 04-13-2012, 05:02 PM - Thread Starter
FpsIsEssential's Avatar
Quoted: 0 Post(s)
Liked: 3
http://pcpartpicker.com/p/6P0f is my build of right now Idk if there is another site with cheaper prices
CPU Intel Core i7-2600K 3.4GHz Quad-Core Processor $299.99 FREE $299.99 @ NCIX US
CPU Cooler Corsair H100 92.0 CFM Liquid CPU Cooler $99.99 FREE $99.99 @ CompUSA
Motherboard Gigabyte GA-Z68XP-UD3P ATX LGA1155 Motherboard $189.99 $4.99 $194.98 @ Newegg
Memory G.Skill Value Series 8GB (2 x 4GB) DDR3-1333 Memory $37.99 FREE $37.99 @ Newegg
Hard Drive OCZ Agility 3 240GB 2.5" Solid State Disk $229.99 -$20.00 FREE $209.99 @ NCIX US
Video Card EVGA GeForce GTX 570 1.25GB Video Card $294.99 FREE $294.99 @ CompUSA
Case Cooler Master HAF 912 ATX Mid Tower Case $59.99 -$10.00 FREE $49.99 @ Newegg
Power Supply Corsair 850W ATX12V / EPS12V Power Supply $134.99 -$10.00 FREE $124.99 @ Newegg
Optical Drive Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer $56.23 FREE $56.23 @ Amazon
Monitor Acer G235HAbd 23.0" Monitor $139.99 $8.99 $148.98 @ Newegg
Acer G235HAbd 23.0" Monitor $139.99 $8.99 $148.98 @ Newegg (2 monitors)
Operating System Microsoft Windows 7 Home Premium SP1 (64-bit) $99.99 FREE $99.99 @ Newegg
Total (before mail-in rebates): $1807.09
Mail-in Rebates: $-40.00
Total: $1767.09
Sound card: Asus Xonar D1 7.1 PCI Sound Card about $70
i7 processor vs server processor ? yes or no/pros and cons
ill prob overclock and how quiet is an h100 is it worth watercooling
i want to be cheap but not to cheap that my comp wont do what i want
so i want to be able to hear very quite sounds but i also want to be able to bump i know this isnt the section for speakers but what will give me good performance for $200 ish i can go over
i play runescape/LoL/Wow/ BF3 etc. i want good graphics and be able to to play with low lag, edit, multitask all the time
i dont want to go over $2000
FpsIsEssential is offline
post #2 of 5 Old 04-13-2012, 05:08 PM
AchuSaysBlessYou's Avatar
Quoted: 0 Post(s)
Liked: 62
for $200 I'd expect to get at least dual 580's.
For 2 570's a 750W is more than enough...
Also, I wouldn't pay more than $250 for a 570 (buy them used if you must for $220 or less)
Server vs. regular processor. Get regular one, Mobo is cheaper. Also, the 2600k is $199.99 in store if you have a Microcenter nearby.
Also, do you NEED a blu-ray drive? Do you have the software to even play Blu-Rays? OEM drives don't come with the software, just FYI.
I'd spend MUCH less on the peripherals and upgrade your GPUs... that's sad performance for a $2000 desktop...
AchuSaysBlessYou is offline
post #3 of 5 Old 04-13-2012, 05:18 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 3
how much is software for blu ray i dont need it but seems like alot of stuff can use blu ray now
well other than an expensive mobo how goood or bad is a server vs normal?
right now i run on a 256mb graphics card i cant even play bf3 pretty say so idk even know what good graphics looks like and my monitor now prob cost like $50 im using a dell from hell , i figured it was a really big psu, and what is a good gtx570 and link to a used one maybe?
post #4 of 5 Old 04-13-2012, 05:27 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 3
for not having alot of money to buy a good water cooling systems is it better to water cool or air cool
post #5 of 5 Old 04-13-2012, 05:37 PM
Quoted: 0 Post(s)
Liked: 62
Your case is good enough for air cooling that you won't need the H100, but with all the fans... well you are getting a HAF (high air flow) which means you kinda expect to have fan noise...
Software for blu-ray playback is $50 (PowerDVD, etc) -> with the price of drive + software, might as well buy a dedicated blu-ray player lol.
Well, again, depends on your current resolution, and with a budget of $2000, i'd expect to play on at least Ultimate with all eye-candy at 1080p
For used 570's Ebay or Overclock.net marketplace
Check out slickdeals.net too.
