Best configuration for gamming - Page 2 - Overclock.net
post #11 of 73 Old 11-20-2012, 11:45 PM - Thread Starter
dattagiri99k's Avatar
Quoted: 0 Post(s)
Liked: 1
@raghu78
thannks a lot dear, bt i thnk i can save over thousand Rs. according to ur calculation ( i dnt need DVD writer )
Bt dear i need a Asrock MOBO intel dnt give good performance....
dattagiri99k is offline
post #12 of 73 Old 11-21-2012, 12:02 AM
Forceman's Avatar
Quoted: 0 Post(s)
Liked: 792
The motherboard makes very little performance difference with new CPUs, and very, very little if you don't plan to overclock the CPU. As long as the motherboard has the features and connections you need, then the brand/model doesn't really matter very much. You don't really need a Z77 motherboard if you don't plan to overclock or run multiple video cards.
Forceman's Law: Any AMD/Nvidia GPU thread, no matter what the topic, will eventually include a post referencing the GTX 970.
Forceman is offline
post #13 of 73 Old 11-21-2012, 12:41 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 1
hey dear
i want to do ONE TIME INVESTMENT....
like if ma price is going too high then i vill omit the HDD and vill take it in future
i mean if i take an ultimate Mobo then i dnt need to change it in future life.....
like once in a life...
i knw that technology is increasing day by day yet... if i plan to overclock ( right now i dnt knw that much , bt in future i vil be able to knw it & vil do overclocking so my configuration shouldnt be lacking anyhwere...... thumb.giftongue.gif
you got me na ... ??
post #14 of 73 Old 11-21-2012, 12:55 AM
*Know-It-All* and proud of it.
mdocod's Avatar
Quoted: 0 Post(s)
Liked: 621
A high end MOBO will go obsolete just as fast as en entry level unit if they share the same primary interfaces (CPU socket, RAM standards, bus speeds, etc). The higher end motherboard typically just offers MORE OF THESE HOLES. There is no such thing as buying into a motherboard for "life." When the CPU actually needs to be upgraded, it will also be time for a new motherboard, RAM, etc because a CPU jump large enough to justify will be on a new socket anyway.
The best value in the long haul is typically to buy into well made but lower priced but high value motherboards, middle tier CPU and GPU, and whatever RAM fits the spec that is known to be of reasonable quality. Every 5-10 years you'll have to do a pretty major system overhaul to get caught up enough to run things smoothly again.
dattagiri99k likes this.
A CPU performance comparison chart.
"Kind of a ring thing, comes with a dialer, you hit the symbols, it spins around and lights come on, it kind of flushes sideways" -O'Neill
mdocod is offline
post #15 of 73 Old 11-21-2012, 01:15 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 1
@mdocod
can u plz also suggest me ... what GPU should i get for me ??
i searched on flipkart & come across these products, bt iam unable to understand the difference... sadsmiley.gif..... beyond Price tongue.gif
the links are as follows :-
1. http://www.flipkart.com/sapphire-amd-ati-hd-7850-hdmi-oc-2-gb-gddr5-graphics-card/p/itmdc2rahtkncpzp
2. http://www.flipkart.com/msi-amd-r7850-power-2gd5-oc-2-gb-gddr5-graphics-card/p/itmdeh4wckedufxn?pid=GRCDEH4WVMVGX2VH&icmpid=reco_pp_historyFooter_graphics_card_2
3.http://www.flipkart.com/sapphire-amd-ati-hd-7870-hdmi-oc-2-gb-gddr5-graphics-card/p/itmdc2rafnxpkg6k?pid=GRCDC2QTMTAHB4ZR&icmpid=reco_pp_personalhistoryFooter_graphics_card_1_nr
& other then that ,, can i know the difference betwn Geforce gtx & this AMD/ATI or sapphireAMD/ATI ??
iam so confused ...... redface.gif and i dnt hve that much knowledge!!!
plz do suggest
post #16 of 73 Old 11-21-2012, 01:51 AM
Makyl's Avatar
Quoted: 0 Post(s)
Liked: 46
Originally Posted by dattagiri99k View Post
@mdocod
plz do suggest
Get the MSI twin frozr. Its cheap and has a decent cooler.
Makyl is offline
post #17 of 73 Old 11-21-2012, 02:34 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 1
thanks a lot.........
love u all.... <3
post #18 of 73 Old 11-23-2012, 12:33 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 1
hey guyz
is amazon.com site trusted ??
shall i buy product frm that site ??
because whenever i compare flipkart with amazon the amazon is way too cheaper then flipkart
& iam frm india ( maharashtra , parbhani )
so plz suggest me
post #19 of 73 Old 11-23-2012, 12:50 AM
Forceman's Avatar
Quoted: 0 Post(s)
Liked: 792
Yes, Amazon.com is trusted, and great. Probably the biggest online store in America.
Forceman is offline
post #20 of 73 Old 11-23-2012, 12:51 AM - Thread Starter
Quoted: 0 Post(s)
Liked: 1
but whenever i buy from there it says
We're sorry. This item can't be shipped to your selected destination. You may either change the shipping address or delete the item from your order. :'(
