Core Duo Build - Need Advice - Overclock.net
post #1 of 33 Old 11-29-2006, 07:12 PM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 48
Updates in Bold 11/29
Updates 11/30
I do not know a lot about the current Intel chips that are out and the best price/performance ratios. I have a buddy who wants to setup a rig for Christmas. Here's the list as it stands right now let me know if it's good or not and what I need to change. Thanks! Budget is $800 +-$20 without the GPU.
GPU - EVGA 7950 GT $220 w/ MIR (His wife already bought him this so no changes here.)
http://shop1.outpost.com/product/497...H:MAIN_RSLT_PG
CPU - E6300 Duo $169 ORDERED
http://shop1.outpost.com/product/489...H:MAIN_RSLT_PG
ZALMAN CNPS9500 LED 2 Ball Cooling Fan with Heatsink - Retail $43
http://www.newegg.com/Product/Produc...82E16835118019
BUFFALO Firestix 2GB (2 x 1GB) DDR2 800 (PC2 6400) $241.99
http://www.newegg.com/Product/Produc...82E16820150054
ASUS P5B-E Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard - Retail $150
http://www.newegg.com/Product/Produc...82E16813131070
OCZ GameXStream OCZ600GXSSLI ATX12V 600W Power Supply - Retail $102
http://www.newegg.com/Product/Produc...82E16817341002
Raidmax Scorpio 668 $70
http://shop1.outpost.com/product/435...H:MAIN_RSLT_PG
REUSED 60G HD
REUSED Monitor/Keyboard/mouse (Need KVM switch)
Total: $796-18
+XP = $841
Thanks for the help!!!!!
~BRISK
And God said:
∇ • E = ρ / εo; ∇ • B = 0; ∇ x E = - ∂B/∂t; ∇ x B = μoJ + μoεo∂E/∂t;
and there was light bulb.gif.
BRISKbaby is offline
post #2 of 33 Old 11-29-2006, 07:15 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 130
Solid rig there. maybe getting a lower end cpu cooler to start off. Or go on board for a while.
BRISKbaby likes this.
OpTioN is offline
post #3 of 33 Old 11-29-2006, 07:17 PM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 48
The only thing I can think of to cut is the ram down to
BUFFALO Firestix 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - OEM$125
http://www.newegg.com/Product/Produc...82E16820150053
This would free up an extra $100 for case and PSU.
Or switching to this motherboard after the ram switch and then having a total of $100 for case/psu/shipping:
eVGA 122-CK-NF68-AR Socket T (LGA 775) NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail $250
http://www.newegg.com/Product/Produc...82E16813188009
post #4 of 33 Old 11-29-2006, 07:18 PM
Kimon's Avatar
Quoted: 0 Post(s)
Liked: 55
Try getting some RAM like this. It looks pretty good and overclocks by the looks of it http://www.newegg.com/Product/Produc...82E16820231087. Also try getting the plain old P5B Deluxe without the WiFi and that can save some cash.
I don't think that the 430W Thermaltake power supply would be a good idea for it. It seems a bit weak for a setup like that. With the savings on those two components I listed above hopefully you could get something around the 500W mark with about 32A combined on the 12V rail. But if you want to shave more money off then maybe getting the Gigabyte DS3 would be a good idea
Kimon is offline
post #5 of 33 Old 11-29-2006, 07:19 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 130
or you could get a Gigabyte S3 mobo for $115 http://www.newegg.com/Product/Produc...82E16813128017
OpTioN is offline
post #6 of 33 Old 11-29-2006, 07:19 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 715
I would say to use the stock Intel cooler for now and maybe get the non-wifi edition if your not going to be using wireless? The Gigabyte DS3 board is also good.
JacKz5o is offline
post #7 of 33 Old 11-29-2006, 07:21 PM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 48
What is the difference in overclocks between the stock cooler vs. the zalman?
EDIT:
Also is there a big jump between the eVGA chipset and the ASUS?
post #8 of 33 Old 11-29-2006, 07:26 PM
Jazino's Avatar
Quoted: 0 Post(s)
Liked: 139
i would consider this as a cooler unless he needs top notch cooling in which he should get something besides the zalman anyway. cant beat $25 shipped http://www.directron.com/acfz7pro.html
Overclock.net 10 Year Member
Jazino is offline
post #9 of 33 Old 11-29-2006, 07:31 PM
Kimon's Avatar
Quoted: 0 Post(s)
Liked: 55
EDIT:
I'd only bother going for the eVGA motherboard if SLI would be something he's going for in the future. But I think he'd be better off with the P5B deluxe and the next video card being something of directx 10 capability.
Kimon is offline
post #10 of 33 Old 11-29-2006, 07:59 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 715
EDIT:
Stock cooler vs Zalman 9700 is a huge difference... but it would be best to save that $60 for a better PSU or something. Even if you have great cooling, you won't be able to OC too high with only a 430W PSU.
JacKz5o is offline
