Are these parts compatiable? First intel build - Overclock.net
post #1 of 9 Old 03-12-2013, 03:56 PM - Thread Starter
1.7ghz
encore018's Avatar
Quoted: 0 Post(s)
Liked: 16
Hi All,
I've been away from the computer building scene for quite some time (my original AMD/ATI build has been going strong for almost 4 years now). My brother recently asked me to help him build a new computer for himself. He's looking to build a fairly strong Intel/nVidia machine. I'd appreciate any input on this build, specifically if all these parts are compatible. These are the parts we picked:
CPU: Intel i7 3770K
Video Card: EVGA GTX 670
MotherBoard: Gigabyte GA-Z77-DS3H
RAM: Corsair CMZ8GX3M2A1600C9B (2x4GB)
SSD: Samsung 120GB MZ-7TD120BW
HDD: Seagate Barracuda 3TB ST3000DM001
PSU: Corsair 650W CMPSU-650TX
Case: Corsair Carbide 200R
Thanks in advance!
-encore018
encore018 is offline
post #2 of 9 Old 03-12-2013, 03:57 PM
Solonowarion's Avatar
Quoted: 0 Post(s)
Liked: 42
Solonowarion is offline
post #3 of 9 Old 03-12-2013, 04:01 PM - Thread Starter
1.7ghz
encore018's Avatar
Quoted: 0 Post(s)
Liked: 16
He'll be doing some gaming, video editing, and running a dual monitor setup. I could've convinced him to pick up some slightly cheaper parts, but he was convinced otherwise. biggrin.gif As for the CPU, we found a great deal, and are going to pick it up for $230! Thanks btw, I appreciate the input.
post #4 of 9 Old 03-12-2013, 05:44 PM
"FineWine®" just means that it's currently swill.
svenge's Avatar
Quoted: 1 Post(s)
Liked: 406
I hope you're not doing too much overclocking with that -DS3H motherboard, as it's Gigabyte's entry-level Z77 model; its VRMs aren't sufficient in number or quality for a decent OC. The very lowest Gigabyte board suitable for OCing is the GA-Z77-D3H.
If you can, get the FTW Edition of EVGA's GTX 670. It uses the PCB and cooling hardware of the 680, which is a nice little upgrade.
svenge is offline
post #5 of 9 Old 03-12-2013, 05:49 PM
Gone
adridu59's Avatar
Quoted: 0 Post(s)
Liked: 313
I'd go with the Plextor M5S for the SSD, also grab a 500W PSU which will be fine for that setup and go with the Gigabyte Z77X-D3H instead, much better motherboard.
Also, current Nvidia cards have terrible GPGPU performance, AMD cards have better value and more memory with additional bandwidth. I'd look into an HD 7950, Sapphire, Gigabyte or HIS are recognized amongst the best. smile.gif
OCN's Recommended: Power SuppliesAudio Products
~ Sig now ToS compliant
adridu59 is offline
post #6 of 9 Old 03-12-2013, 05:52 PM
shilka's Avatar
Quoted: 0 Post(s)
Liked: 2696
shilka is offline
post #7 of 9 Old 03-12-2013, 05:52 PM
shilka's Avatar
Quoted: 0 Post(s)
Liked: 2696
650 watts is a litte overkill for a system like that yes 500-550 watts would be fine
http://www.overclock.net/t/183810/faq-recommended-power-supplies
shilka is offline
post #8 of 9 Old 03-13-2013, 04:54 PM - Thread Starter
1.7ghz
encore018's Avatar
Quoted: 0 Post(s)
Liked: 16
Thanks for the input guys, I decided to get the 650W PSU, since it was basically a steal from newegg ($65). I also decided on the cheaper motherboard, because this machine won't be overclocked. As much as I would like to, I know that I won't be around to maintain and monitor it, so I'm deciding against it.
post #9 of 9 Old 03-13-2013, 07:14 PM
svenge's Avatar
Quoted: 1 Post(s)
Liked: 406
In that case, the -DS3H will be fine @ stock clocks.
svenge is offline
