finshed system need help overlocking - Overclock.net
post #1 of 5 Old 12-22-2006, 11:00 AM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 5
ok i just finished my system and i need help overclocking it. i got the E6300, g-skill ddr2-800 with 4-4-4-12 timing (1.8-2.0v) and the gigabyt ga-p965-ds3 board, what i need is that settings i shoudl set everything at thanks.
languy99 is offline
post #2 of 5 Old 12-22-2006, 01:01 PM
Commodore 64
deadlydude's Avatar
Quoted: 0 Post(s)
Liked: 2
This is a very detailed good guide...
http://forumz.tomshardware.com/hardw...ict197995.html
GIGABYTE GA-965P-DS3
Intel Core 2 Duo E6300
Zalman CNPS9500-AT
CORSAIR XMS2 1GB (2 x 512MB) DDR2 800
SAPPHIRE Radeon X1900XT 256MB GDDR3
Ultra X-Finity 600W PSU
Antec NineHundred
http://valid.x86-secret.com/show_oc?id=145591
deadlydude is offline
post #3 of 5 Old 12-22-2006, 01:58 PM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 5
yeah i have that guide and the only part i am having trouble with is that voltages especially with that mch and fsb in the bios it does not give you what it starts out as, only the increase, so how do i know when i have reached the right voltage and also i can't find the sb voltage anywhere. Also how to i lock the PCI because i can't seem to find that and lastly when i run a stress test i can hear this high pitched whistley noise is that normal, when i stop running the stress test it goes away?
languy99 is offline
post #4 of 5 Old 12-23-2006, 07:17 AM
Commodore 64
Mac Grape's Avatar
Quoted: 0 Post(s)
Liked: 0
I have the same problem as you, it seems easy when they say up the voltage to this much but the DS3 bios doesn't say what it is to begin with. Just says +1 or something.
I have been running the stress test on 2 diff OC settings. Did not change any of the voltage but only changed fsb which in turn changed the ram and i set my ram timings to 4-4-4-12 as well as vcore to 1.35. So far, I have this:
Stress test been on for 8hrs and no errors but no high pitching noise. However, I do worry about the temperatures, anybody know what it should read at?
Im assuming the high pitching noise is not normal. Do you see any problems or everything stable so far?
Mac Grape is offline
post #5 of 5 Old 12-23-2006, 10:12 AM - Thread Starter
733mhz
Quoted: 0 Post(s)
Liked: 5
what frequency are you running on that ram? i have been playing with it and i got it stable at 400fsb but i had to raise the voltages to to pretty much everything, i was trying to get it stable at 415fsb but i think i had to go to 1.4V on the vcore, and i was only running at 1.37. but right now i am trying to get it stable at 375fsb with a 1.5vcore, and 4-4-4-12 ram setting. we'll see how it goes. i want to get it rock solid at this setting and than move on.
languy99 is offline
