Fixing Hardware Problems in a Water Cooled PC - Page 2 - Overclock.net
post #11 of 13 Old 09-13-2013, 08:10 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 11
Originally Posted by speedytech7 View Post
Do you have a motherboard that allows you to re-flash the BIOS with a flash drive and the little button. It is a special ASUS and some other brand feature that requires you to plug the drive with the BIOS file (.bin or .cap) into a special labelled USB port and push a small button to flash it while it is off. Doesn't need a CPU, RAM, GPU, or anything but the motherboard and a plugged in power supply.
Yes, I forgot about that. I will give that a try.
rossb is offline
post #12 of 13 Old 09-13-2013, 09:18 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 11
Just re-flashed the BIOS as suggested. It worked! That seems to have fixed the problem. Thanks speedytech7 and others for the suggestions!
rossb is offline
post #13 of 13 Old 09-13-2013, 09:26 PM
Intel Overclocker
speedytech7's Avatar
Quoted: 0 Post(s)
Liked: 15
"Overclocking is an art... I demand recognition!"
Intel or AMD - Just depends on what you're doing
speedytech7 is offline
