[Build Advice] Best Value Intel Mobo/CPU using DDR3 - Page 2 - Overclock.net
post #11 of 11 Old 09-27-2015, 10:03 PM - Thread Starter
Commodore 64
BootLoops's Avatar
Quoted: 0 Post(s)
Liked: 0
Originally Posted by brucethemoose View Post
Ya, the price is the big sticking point. I haven't checked in awhile, so I figured it would've come down by now... Guess I'm wrong :/.
The oversized IGP doesn't matter (assuming you don't use it for any decoding), but the 128MB of L4 cache the whole CPU can use does. I'm not sure about your stock trading apps, but it really speeds up some very specific workloads.
EDIT: Note that TR isn't using particularly fast DDR3/DDR4 in that review, which is why the gap is closer on some other sites.
It doesn't really matter now though, as its really close to a 4790k anyway.
Well it was worth some research, anyway. Thanks for the input!
BootLoops is offline
