big problem with VCORE! and ram?? - Overclock.net
post #1 of 26 Old 02-25-2008, 03:47 AM - Thread Starter
Commodore 64
denzow's Avatar
Quoted: 0 Post(s)
Liked: 0
i have a
ABIT IX38-QuadGT, X38, Socket-775, GbLAN ATX, Otes, GbLAN, DDR2, 3xPCI-Ex(2.0)x16 motherboard.
CPU is Q6600 G0
and when i change the FSB to 340 x 9 multiplier = 3.06 ghz
and i set the user defined, volt to 1.36, and its ok. i restart the computer, boots windows..
and when i open SpeedFAN\\CPU-Z it says its using volt 1.46\\1.60 ?
i've even tried to set it at volt 1.00(i know its very low, but its just for testing) for CPU, but when i check with CPU-Z it says its 1.46 still.. what do i need to do??
And i have these RAM chips
Crucial DDR2 BallistiX PC8500 2048MB CL5 ,Kit w/two matched BallistiX 128Megx64
i have 4gib total, when i check in CPU-Z it says theyre running at 400mhz??
it says in the info about the RAM that it is 1066mhz ram?, how can i get atleast 800mhz with them?
Please help me! thank you..
denzow is offline
post #2 of 26 Old 02-25-2008, 03:56 AM
mklvotep f@h
markt's Avatar
Quoted: 0 Post(s)
Liked: 135
You need to fill in system specs in user cp.I don't think your cpu is listed there.
markt is offline
post #3 of 26 Old 02-25-2008, 04:04 AM - Thread Starter
Commodore 64
denzow's Avatar
Quoted: 0 Post(s)
Liked: 0
i have a Quadcore Q6600 G0 CPU.. Ive added it to my profile now
denzow is offline
post #4 of 26 Old 02-25-2008, 06:37 AM - Thread Starter
Commodore 64
denzow's Avatar
Quoted: 0 Post(s)
Liked: 0
Buuuump :=)
denzow is offline
post #5 of 26 Old 02-25-2008, 07:40 AM
4.0ghz
SentryOptic's Avatar
Quoted: 0 Post(s)
Liked: 101
Disable speedstep in BIOS.
It sounds like your board is overvolting the CPU, might just be a technical glitch or something.
Still though, I'd take it down a bit. Or get another program and see if it reads the same things.
And leave your RAM voltage at about 2.0v. Don't go any higher. Change the FSB to 320x9 and slowly work your way up.
Gee, Nostradamus, any other shocking predictions you'd like to share?
Weighted Companion Cube Scratch Build
Part 1 Part 2
_____________________________________
Synthesis Case
Completed Worklog
SentryOptic is offline
post #6 of 26 Old 02-25-2008, 09:54 AM - Thread Starter
Commodore 64
denzow's Avatar
Quoted: 0 Post(s)
Liked: 0
i tried to turn of speed step now, but it still overvolts the CPU, i run DEFAULT freq on the CPU now, 266 x 9 = 2398mhz.. the default. but the CPU gets about 1.368V.. anybody know why? and my ram is running only 400mhz? why? its supposed to be 1066mhz?
denzow is offline
post #7 of 26 Old 02-25-2008, 10:01 AM
4.0ghz
smokinbonz's Avatar
Quoted: 0 Post(s)
Liked: 111
I acn tell you when i set the vcore in my mobo it doesnt exately match. so for me it was a matter of saving the bios and running cpuz or re checking the voltage in the bios hardware manager.
so my ram is set at +.5v when it should be +.4 volts if i were to go by the bios to acheive 2.2v
my cpu is set at 1.38something to acheive 1 .34vcore so in my case the bios setting isnt really etched in stone its an approximation and not actually the voltage hope this helps you out
smokinbonz is offline
post #8 of 26 Old 02-25-2008, 11:00 AM - Thread Starter
Commodore 64
denzow's Avatar
Quoted: 0 Post(s)
Liked: 0
If you watch that image file, you can see that the uGURU has the exact corevolt that i set in BiOS; but CPU-Z and SPEEDFAN shows different.. wich is the right one of them :\\ ?
denzow is offline
post #9 of 26 Old 02-25-2008, 11:05 AM
a.k.a. TutenStain
Quoted: 0 Post(s)
Liked: 646
Send a message via MSN to i_ame_killer_2
Originally Posted by denzow View Post
If you watch that image file, you can see that the uGURU has the exact corevolt that i set in BiOS; but CPU-Z and SPEEDFAN shows different.. wich is the right one of them : ?
I can almost see it....
Please ignor my spelling and grammar!
FAQ:s
I reject your reality and substitute my own. -Adam Savage
i_ame_killer_2 is offline
post #10 of 26 Old 02-25-2008, 11:09 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 42
Sounds like your board isnt working right, or doesnt support your CPU? or those programs both use the same type of measurment, which doesnt work on your board. look for other utilitys that show the same values as the BOIS.
Also, try like 1.2 or something, 1.0 is so low it could cause problems for a quad, I THINK.
all your ram are belong to Vista.
There are no girls on the Internet. On the Internet, all men are men, all girls are men, and all children are the FBI
davek is offline
