I have about $70 to spend - Page 2 - Overclock.net
post #11 of 64 Old 03-04-2008, 07:58 AM - Thread Starter
Lysdexik's Avatar
Quoted: 2 Post(s)
Liked: 128
so I shouldn't invest in a GPU cooler?
absolutely not.
Lysdexik is offline
post #12 of 64 Old 03-04-2008, 08:03 AM
ZealotKi11er's Avatar
Quoted: 6 Post(s)
Liked: 1787
Why not save it. 70 now means less for your next GPU upgrade.
CPU History (Click to show)
CPU -> Sempron 2400+, Athlon 64 3700+, Core 2 Q6600, A8-3870K, Core 2 Q9550, Core 2 QX9770, Core i7 920, Core i5 2500K, Core i5 3570K, Phenom II X4 955, Core i7 3770K.
GPU History (Click to show)
FX 5200 128MB, 9800 Pro 128MB, 6800GS 256MB, 7600GT 256MB, HD 4850 512MB, HD 4870 1GB, 2x HD 4870 1GB, GTX280 1GB, HD 5850 1GB, GTX470 1.25GB, GTX580 1.5GB, HD 6950 2GB, HD 6950 2GB + HD 6970 2GB, HD 6990 2GB, HD 7970 3GB, 2 x HD 7970 3GB,R9 290 4GB, R9 290X 4GB, R9 Fury X 4GB, GTX 1080 8GB, GTX1080 Ti 11GB
MB History (Click to show)
ECS KN1 Extreme -> ASUS P5Q-E -> GIGABYTE GA-X58A-UD7 -> GIGABYTE GA-Z68XP-UD4 -> GIGABYTE GA-Z77X-UD5H -> ASRock Z77E-ITX
Chimp Challenge Participant  Overclock.net 10 Year Member
ZealotKi11er is offline
post #13 of 64 Old 03-04-2008, 08:05 AM - Thread Starter
Lysdexik's Avatar
Quoted: 2 Post(s)
Liked: 128
I won't be upgrading my GPU for a long time, my mobo doesn't support SLI.
absolutely not.
Lysdexik is offline
post #14 of 64 Old 03-04-2008, 08:08 AM
4.0ghz
SANNIN3Xjima's Avatar
Quoted: 0 Post(s)
Liked: 219
I think you're fine the way you are.
The only worth while option is the hard drive.
If you plan to overclock, get a GPU cooler.
http://www.crazypc.com/store/merchan...Category_Code=
If you are going to buy watercooling kits, cheap is not the way to go. You would have to spend at least $150. And I suggest making your own watercooling kit by buying parts as well, not the pre-made kits as they are not as efficient, from what I have been told.
javascript/ジャバスクリプト:profit calculator
SANNIN3Xjima is offline
post #15 of 64 Old 03-04-2008, 08:12 AM
4.0ghz
Criswell's Avatar
Quoted: 0 Post(s)
Liked: 134
I'd get a Hard Drive or a GPU Heatsink.
Criswell is offline
post #16 of 64 Old 03-04-2008, 11:15 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 66
At 19 you can save it for that chica you're probably going to be taking out on a fancy date ;P
Anyway just trying to say your setup looks good to me trying to help you think outside the box lol... no pun intended lol...
SELECT * FROM users WHERE clue > 0;
"It’s not a bug in the game’s code, it’s a bug in your moral code."
2Luke2 is offline
post #17 of 64 Old 03-04-2008, 11:23 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 66
Here's a good way to look at it... Computer componets always get cheaper and women always get more expensive ;P
2Luke2 is offline
post #18 of 64 Old 03-04-2008, 04:26 PM - Thread Starter
Lysdexik's Avatar
Quoted: 2 Post(s)
Liked: 128
Would it be worth it to RMA my mobo and spend an extra hundred bucks to get the evga 780i board
absolutely not.
Lysdexik is offline
post #19 of 64 Old 03-04-2008, 04:29 PM
PC Gamer
Munchkinpuncher's Avatar
Quoted: 0 Post(s)
Liked: 144
New sound card?
Steam: Munchkinpuncher
Origin: Blackwatur
Xbox Live: Blackwatur
Munchkinpuncher is offline
post #20 of 64 Old 03-04-2008, 04:32 PM - Thread Starter
Lysdexik's Avatar
Quoted: 2 Post(s)
Liked: 128
Originally Posted by Munchkinpuncher View Post
New sound card?
my current mobo has optical out I think so I don't need a sound card
absolutely not.
Lysdexik is offline
