newb question - Overclock.net
post #1 of 12 Old 03-05-2008, 09:24 PM - Thread Starter
3.5ghz
cleverchris's Avatar
Quoted: 0 Post(s)
Liked: 41
alright so my motherboards says it supports DDR2-800 can I put in 1066 and have it work at that speed or would it be useless....I have a intel 975Xbx2...I was wondering this because I should be able to overclock way past 3.2 Ghz with my set-up...if anyone could just take a whole look at my system so I can find what is tripping me up ...thanks
cleverchris is offline
post #2 of 12 Old 03-05-2008, 09:25 PM
AKA Murclocke
Murlocke's Avatar
Quoted: 0 Post(s)
Liked: 911
It will work at 800 and maybe 1066.
Honestly, if your stuck at 3.2GHz don't worry about it... It means absolutely nothing in games unless your running at 1280x1024.
Murlocke is offline
post #3 of 12 Old 03-05-2008, 09:26 PM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 41
maybe 1066 can you explain further
post #4 of 12 Old 03-05-2008, 09:27 PM
4.0ghz
l V l's Avatar
Quoted: 0 Post(s)
Liked: 266
Wait, I read the question wrong... So you want to put 1066 ram in a motherboard with support for standard 800?
l V l is offline
post #5 of 12 Old 03-05-2008, 09:30 PM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 41
yes .. i have no clue if it would work i wouldn't think it would but then a Q6600 is rated at 2.4 Ghz
oh and I run @ 1680 *1050 also I do 3d rendering and video edits so the extra Mhz would help
post #6 of 12 Old 03-05-2008, 09:34 PM
4.0ghz
SANNIN3Xjima's Avatar
Quoted: 0 Post(s)
Liked: 219
Yes you can use it over.
javascript/ジャバスクリプト:profit calculator
SANNIN3Xjima is offline
post #7 of 12 Old 03-05-2008, 09:35 PM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 41
ok thanks for that answer...never rly understood how people overclock RAM because there is no option for clocking it over like cpu has fsb
post #8 of 12 Old 03-05-2008, 09:42 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 219
There are options to overclock the ram's speed. It should be located in the BIOS, but every motherboard is different. I have used ASUS's bios and it was simple, it was under the manual configurations for overclocking the ram's latency.
post #9 of 12 Old 03-05-2008, 09:47 PM - Thread Starter
3.5ghz
Quoted: 0 Post(s)
Liked: 41
yes i have that and I mess with it quite often but I have no way of telling if its changing the frequency of it ...I mean i have xms2 ddr2-800 and there is a reference freq i have set @ 266 and the reg RAM freq @ 800 and then the timings which I have @ 5-5-5-18 ...I could put themat 4-4-4-12 but I have to drop to 667Mhz ...but my question is how am I supposed to clock over ?!?! its a complete mystery to me
post #10 of 12 Old 03-05-2008, 09:58 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 219
What do you mean clock over? Loosen your timings then? Find a good divider?
