Rate my desktop and give advice - Overclock.net
post #1 of 2 Old 04-14-2011, 04:47 PM - Thread Starter
1.3ghz
ukieman1212's Avatar
Quoted: 0 Post(s)
Liked: 5
so just rate this setup
CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
VIDEO CARD: MSI N460GTX CYCLONE 1GD5/OC GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
HARDRIVE: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
MEMORY: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBXL
MOBO: MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CPU FAN: COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
DVD DRIVE/ BURNER: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk – OEM
MEMORY READER: Rosewill RCR-IC001 40-in-1 USB 2.0 3.5" Internal Card Reader w/ USB Port / Extra Silver Face Plate
PSU: Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified ...
CASE: Xion Vulcan 601 Black Blue ATX Mid Tower Case 4X5.25 2X3.5 5X3.5INT 1X120MM 1X90MM LED Fan No PSU (CSXION-601)
Windows Ultimate 64-bit(already had)
:drum:FOR $1200 drum.gif
Give advice on build below
ukieman1212 is offline
post #2 of 2 Old 04-15-2011, 06:28 AM
4.0ghz
Kal777's Avatar
Quoted: 0 Post(s)
Liked: 169
not bad, little underpowered in the graphics though, get SLi in there
Kalum
Kal777 is offline
