Help with build- CPU fan error - Overclock.net
post #1 of 2 Old 10-16-2013, 09:48 PM - Thread Starter
333mhz
gabsonuro's Avatar
Quoted: 0 Post(s)
Liked: 26
So i swapped out my current rig into a new case, a Corsair 300r windowed. I also picked up 3 new fans, all three of them being corsair quiet PWM fans. I put two up top, and replaced the stock corsair H60 fan with one of the PWM fans. I plugged the PWM fan into the CPU_FAN header, and the H60 pump into a standard 3 pin fan outlet. How can i solve this problem? My mobo is a Sabertooth P67.
"There are only two types of player, those who keep their nerves in control and win championships and those that do not."
gabsonuro is offline
post #2 of 2 Old 10-16-2013, 09:56 PM
MrTOOSHORT's Avatar
Quoted: 0 Post(s)
Liked: 1495
Get into your bios and find CPU Fan Speed and put that to ignore.
Might help.
3dmark11   GTX480 GTX570 7970GTX680GTX690TITANGTX780TITITAN XGTX1080TITAN X (P)
MrTOOSHORT is online now
