Rampage III Extreme POST/Boot Issues - Overclock.net
post #1 of 13 Old 06-10-2010, 06:31 PM - Thread Starter
SLAPPA DAT BASS MON!
xxbassplayerxx's Avatar
Quoted: 0 Post(s)
Liked: 610
I got this today from Newegg. I bought it open box and I'm starting to feel there was a reason this was returned...
Anyways. It posted fine the first time. I installed drivers and then restarted. After that, I set a small overclock. When I hit F10 to restart, the rig restarted but the video never came up.
Without a hard reset between every change, the video doesn't come up.
So that's all fine and dandy, but now when I try to boot, it is the slowest thing ever. The text that Windows loads to ask if I want to boot into XP or 7 loads one letter at a time. When the Windows 7 splash screen finally comes up, the four colored orbs move a frame every few seconds. In fact, I'm running on 10 minutes for the boot right in front of me.
It's happening, it's just really slow.
So far, this has been a terrible purchase. I'll RMA as a last resort... but I want to get this thing working.
xxbassplayerxx is offline
post #2 of 13 Old 06-10-2010, 06:34 PM
4.0ghz
DorkSterr's Avatar
Quoted: 0 Post(s)
Liked: 163
What BIOS are you using?
Nikon D4 || Nikon 14-24mm f/2.8 || Nikon 24-70mm f/2.8 || Nikon 105mm f/2.8 || Nikon 28-300mm f/3.5-5.6 || Sigma 50-500mm f4.5-6.3 OS || Gitzo GT1542T + Gitzo GH1780QR || Manfrotto 055XPROB + Manfrotto 498RC4 || Nikon SB700 Speedlight + Lightsphere II Cloud || Kenko Extention Tube Set
IEM's: Shure SE535 - Westone 3 - Earsonic SM3 - Sennheiser IE8
HeadPhones: Bowers & Wilkins P5 - Ultrasone Edition 8 - Shure SRH840
DorkSterr is offline
post #3 of 13 Old 06-10-2010, 06:37 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 610
0402. I'm about to upgrade to 0602.
Is 0402 that bad? I can't believe that they would release a BIOS that would do all this stuff I'm experiencing.
Anyways, I'll let you know if a BIOS update works.
post #4 of 13 Old 06-10-2010, 06:40 PM
4.0ghz
DorkSterr's Avatar
Quoted: 0 Post(s)
Liked: 163
It's not bad, I didnt have any probles with it. I asked because updating your BIOS might fix some of the problems.
post #5 of 13 Old 06-10-2010, 06:50 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 610
Updating the BIOS did not help. I watched the the ROG connect thing and it's actually booting... it just doesn't start the VGA BIOS. I saw a setting that was like S3 VGA BIOS RESUME so I tried that... but no luck.
post #6 of 13 Old 06-10-2010, 06:54 PM
4.0ghz
kasuza's Avatar
Quoted: 0 Post(s)
Liked: 87
You should buy a brand new on tigerdirect.com for $300 free shipping. RMA back to newegg.com - free shipping or RMA to Asus.
Asus Crosshair IV Formula/Extreme Club
kasuza is offline
post #7 of 13 Old 06-10-2010, 07:01 PM
4.0ghz
DorkSterr's Avatar
Quoted: 0 Post(s)
Liked: 163
Have you tried different PCI-E slots? Make sure all your PCI-E slots are set to 'ON' on the switched where the memory DIMM are.
post #8 of 13 Old 06-10-2010, 07:27 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 610
They are all set to on. I've tried the first and second.
If I change any settings at all in the BIOS it won't boot. It's stopped the slow boot thing.
I was able to boot up at 4.2GHz once earlier. Not any more...
Anyone using one of these with a 920 want to throw their settings my way? I'm really not liking how this BIOS is laid out. Maybe I'm missing something.
post #9 of 13 Old 06-10-2010, 07:32 PM
4.0ghz
DorkSterr's Avatar
Quoted: 0 Post(s)
Liked: 163
Man this is so weird. I really hate it when people dont get the satisfaction for what they paid for.
What are your settings it the bios? When you OC do you use CPU level up? Maybe you are not putting enough voltages on the memory or CPU? This happens to me too when I start an OC and dont put enough voltages.
post #10 of 13 Old 06-10-2010, 07:40 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 610
Is there a BIOS template for this somewhere? I'd prefer not to type everything out.
EDIT: Found one... Updating with settings.
Target CPU Frequency                  4200MHz
Target DRAM Frequency                 1603MHz
LN2 Mode                              []***
QPI Loadline Calibration              []***
Sync Mode                             [Enabled]
AI Overclock Tuner                    [Manual]
OC From CPU level Up                  [Auto]
CPU Ratio Setting                     [21.0]
CPU Turbo Power Limit                 [Disabled]
>CPU Configuration----------------------------
C1E Support                           [Disabled]
Hardware Prefetcher                   [Enabled]
Adjacent Cache Line Prefetcher        [Enabled]
Intel(R) Virtualization Tech          [Enabled]
CPU TM Function                       [Enabled]
Execute Disable Bit                   [Enabled]
Intel(R) HT Technology                [Enabled]
Active Processor Cores                [All]
A20M                                  [Disabled]
Intel(R) SpeedStep(TM) Tech           [Disabled]
Intel(R) C-STATE Tech                 [Disabled]
C State package limit setting         []
BCLK Frequency                        [200]
PCIE Frequency                        [105]
DRAM Frequency                        [DDR3-1603MHz]
UCLK Frequency                        [3408MHz]
QPI Link Data Rate                    [7217MT/s]
Memory Configuration Protect          [Disabled]
>DRAM Timing Control--------------------------
CAS# Latency                          [7 DRAM Clock]
RAS# to CAS# Delay                    [7 DRAM Clock]
RAS# PRE Time                         [7 DRAM Clock]
RAS# ACT Time                         [21 DRAM Clock]
RAS# to RAS# Delay                    [Auto]
REF Cycle Time                        [Auto]
WRITE Recovery Time                   [Auto]
READ to PRE Time                      [Auto]
FOUR ACT WIN Time                     [Auto]
Back-To-BackCAS# Delay                [Auto]
Timing Mode                           [1N]
Round Trip Latency on CHA             [Auto]
Round Trip Latency on CHB             [Auto]
Round Trip Latency on CHC             [Auto]
WRITE To READ Delay(DD)               [Auto]
WRITE To READ Delay(DR)               [Auto]
WRITE To READ Delay(SR)               [Auto]
READ To WRITE Delay(DD)               [Auto]
READ To WRITE Delay(DR)               [Auto]
READ To WRITE Delay(SR)               [Auto]
READ To READ Delay(DD)                [Auto]
READ To READ Delay(DR)                [Auto]
READ To READ Delay(SR)                [Auto]
WRITE To WRITE Delay(DD)              [Auto]
WRITE To WRITE Delay(DR)              [Auto]
WRITE To WRITE Delay(SR)              [Auto]
CPU Differential Amplitude            [Auto]
CPU Clock Skew                        [Auto]
IOH Clock Skew                        [Auto]
------------ Extreme Engine Digi+ ------------
Digi+ PWR Mode                        [X-Power]
PWR Volt. Control                     [Auto]
Load-Line Calibration                 [50% Calibration]
CPU Voltege OCP                       [Enabled]
CPU PWM Frequency                     [Auto]
Extreme OV                            [Disabled]
Extreme OC                            [Auto]
CPU Voltage                           [1.45000]
CPU PLL Voltage                       [1.90800]
QPI/DRAM Core Voltage                 [1.38125]
DRAM Bus Voltage                      [1.70925]
>DRAM REF Voltages----------------------------
DRAM DATA REF Voltage on CHA          [Auto]
DRAM CTRL REF Voltage on CHA          [Auto]
DRAM DATA REF Voltage on CHB          [Auto]
DRAM CTRL REF Voltage on CHB          [Auto]
DRAM DATA REF Voltage on CHC          [Auto]
DRAM CTRL REF Voltage on CHC          [Auto]
IOH Voltage                           [1.24550]
IOH PCIE Voltage                      [1.51050]
ICH Voltage                           [1.24550]
ICH PCIE Voltage                      [1.51050]
---------- Spread Spectrum Control -----------
CPU Spread Spectrum                   [Auto]
DRAM Spread Spectrum                  [Auto]
***on-board jumper dependant
