Dedicated graphics going to waste? - Overclock.net
post #1 of 9 Old 03-12-2013, 07:04 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 11
Hi everyone,
It's been a long time since I have posted here, but this was always a great place for help so I come to you with this question.
I'm using the laptop in the sig below which I specifically bought for its graphics chip (GT330M) with 1GB of dedicated VRAM in order to be able to play games. I will now cut to the chase: I used run > dxdiag.exe to check my hardware and here is the beginning of the display section:
Display Devices
Card name: Intel(R) Graphics Media Accelerator HD
Manufacturer: Intel Corporation
Chip type: Intel(R) Graphics Media Accelerator HD (Core i3)
DAC type: Internal
Device Key: Enum\PCI\VEN_8086&DEV_0046&SUBSYS_04341025&REV_02
Display Memory: 1755 MB
Dedicated Memory: 128 MB
Shared Memory: 1627 MB
Current Mode: 1366 x 768 (32 bit) (59Hz)
Monitor Name: Generic PnP Monitor
What am I missing? Anyone have any insight as to why my system defaults to the ****ty intel graphics and how I might fix it?
Thanks
I mean the only thig that wouldnt suck from microsoft is a Vaccum cleaner.
That_Guy is offline
post #2 of 9 Old 03-12-2013, 11:16 PM
WaterCooler
Quoted: 0 Post(s)
Liked: 17
Well, your system defaults to the intel chip because that is what is designed to run when you are not playing games. When you play games, it should switch to the dedicated graphics. Are you having issues running games? or are you basing this all off the fact that dxdiag is telling you that it is the default display device?
Chimp Challenge 2 x Participant  10 Million+ Folding at Home points
Mast3rRoot is offline
post #3 of 9 Old 03-12-2013, 11:33 PM
Audiophile
kenpachiroks's Avatar
Quoted: 0 Post(s)
Liked: 49
Think of it as "on demand" use. Its called "nvidia hybrid" or "nvidia optimus" (not sure about the name)
It will utilize your 330M for graphics heavy applications.
Do you have performance issues? The integrated chip will be able to run most games on low settings only.
If you don't, then don't worry about this.
Just make sure your drivers are updated.
PS : Still, if you want to define what graphics card a application should use you can set it in the NVIDIA control panel>Manage 3D settings>Program settings>(select application)>NVIDIA(from the drop down menu.
Overclock.net 10 Year Member
kenpachiroks is offline
post #4 of 9 Old 03-13-2013, 12:28 AM
Moderator
Penryn's Avatar
Quoted: 1 Post(s)
Liked: 111
Nvidia optimus defaults to the Intel GPU when not gaming to save power. You can force it on but your battery life will suffer.
I am a Google Pixel XL user.
This hand of mine is BURNING RED! Its loud roar tells me to grasp victory! ERUPTING BURNING FINGER!
Penryn is offline
post #5 of 9 Old 03-13-2013, 04:32 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 11
Thanks for the replies so far.
I have tried using the nvidia control panel to force my system to use it all the time just to test. This did not work (at least according to dxdiag). I tried forcing it to use nvidia for the application of interest (StarCraft II). This did not work either (I tried running the diagnostic while in game). Then I tried disabling the intel graphics. Whoops: I needed safe mode to fix that.
The question about performance: I am only able to play really old games on anything other than low without issues. I don't have too many games, but I can confirm that SC2, Civ5, and Endless Space are all on lowest settings and tend to lag once there are a lot of objects on screen (like mid game in SC--forcing me to rush every time)
My drivers are up to date.
Help?
Edit: Add Tropico 4 and BF2142 to the list of games that run on low
That_Guy is offline
post #6 of 9 Old 03-13-2013, 10:29 PM
Quoted: 2 Post(s)
Liked: 445
You might have to specifically set each game up in the control panel. I know there are a few others who had to do just that to get things working properly. redface.gif
Awesome Quotes (Click to show)
I'm not worried in the least. I haven't taken anti-biotics in 12 years and I constantly lick my hands to build disease resistance.
My immune system is impenetrable.
Windows XP is like a boss in a game that can heal it self. IT WON'T DIE!
If you watch Jaws in reverse, it's about this shark that throws up so many people they had to open a beach because of it.
Hey cutie, wanna meet my friend BIOS ? It stands for Basic, input, outpu..SLAP!!
Giggidy.
Imglidinhere is offline
post #7 of 9 Old 03-14-2013, 05:07 PM
Moderator
Penryn's Avatar
Quoted: 1 Post(s)
Liked: 111
Dxdiag will always show the Intel card. My m14x does the same thing with the gt555. Also the gt330 is not the best card so I'm guessing running on low would be the best that it can do anyways and get playable frames.
Penryn is offline
post #8 of 9 Old 03-14-2013, 06:41 PM
Overclocker
Domino's Avatar
Quoted: 0 Post(s)
Liked: 247
Overclock the crap out of that GT330. It only has 48 stream processors.
Domino is offline
post #9 of 9 Old 03-14-2013, 08:17 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 11
That makes sense. I was wondering if the dx diagnostic was really a reliable measure.
Interesting idea but the machine already gets extremely hot and will shut itself off after not too much game time unless i prop it up and put a fan directly on it. Do you think it could handle an OC?
That_Guy is offline
