HP TX1000 Downgrade to XP, Works with a lil glitch... - Overclock.net
post #1 of 13 Old 03-02-2008, 08:42 PM - Thread Starter
Y3K
1.3ghz
Quoted: 0 Post(s)
Liked: 11
Ive installed XP on my HP tx1000 tablet PC for the second time, in hopes of to finally make a stable OS, well, this is probably the closest ive gotten.
I downgraded from vista to xp, ive managed to get most of the drivers, but im still having a flaw.
1. Ive noteiced my CPU clock speeds keep jumping up and down only when
the CPU is on full load.
2. In device manager i notice theres an unknown device "CoProcesser"
Also note the CPU clock is normal again.
If anyone has any ideas were i can get the driver for the coprocesser, that would improve performance.
-Straight to the moon...
Y3K is offline
post #2 of 13 Old 03-02-2008, 08:50 PM
1:14 Camera:People Ratio
Quoted: 0 Post(s)
Liked: 338
Just a thought, but perhaps it's a glitch in CPU-Z? Have you verified CPU-Z's readings with another program?
Highly-Annoyed
Wise men speak because they have something to say; Fools because they have to say something. -Plato
Talk sense to a fool and he calls you foolish. -Euripides .. Terrifying are the weaknesses of power. -Greek Proverb
exclamation.gifMy Favourite Windows XP Freeware Page . ...' ..'.exclamation.gif Wowza's Core 2 Duo Motherboard Analysis
Highly-Annoyed is offline
post #3 of 13 Old 03-02-2008, 09:05 PM - Thread Starter
Y3K
1.3ghz
Quoted: 0 Post(s)
Liked: 11
Yes, true, here is an other screen shot using a diff CPU vert.
As you can see, still the same...
I looked into the BOIS and its set to "performance", as with the Nforce settings... still does it
Y3K is offline
post #4 of 13 Old 03-02-2008, 09:32 PM
1.7ghz
Quoted: 0 Post(s)
Liked: 26
http://www.pbus-167.com/
Try that. You can switch speeds
Y3K and arekieh like this.
seaneyo99 is offline
post #5 of 13 Old 03-02-2008, 09:59 PM - Thread Starter
Y3K
1.3ghz
Quoted: 0 Post(s)
Liked: 11
Sweet! Thanks +Rep, now any ideas about the CoCPU?
I know its something with the chipset drivers, but ive installed them 3 times now, and it still giving its not installed...
Y3K is offline
post #6 of 13 Old 03-02-2008, 10:07 PM
Quoted: 0 Post(s)
Liked: 256
does your turion support cool n quiet? if it does and it is enabled in the bios that would explain your proc speeds changing
There are some things that smoke can come out of and still be good, for instance, a bong. Bad things for smoke to come out of, computer parts.
Overclock.net 10 Year Member
sli_shroom is offline
post #7 of 13 Old 03-02-2008, 10:24 PM - Thread Starter
Y3K
1.3ghz
Quoted: 0 Post(s)
Liked: 11
No, i looked thought the BIOS, and nothing in there. Its just a simple OEM BIOS...
Y3K is offline
post #8 of 13 Old 03-02-2008, 10:29 PM
1.7ghz
Quoted: 0 Post(s)
Liked: 26
Does the touch screen work?
post #9 of 13 Old 03-02-2008, 10:44 PM - Thread Starter
Y3K
1.3ghz
Quoted: 0 Post(s)
Liked: 11
Now , sadly i got the lowest possible model that does not include the touch screen...
Y3K is offline
post #10 of 13 Old 03-03-2008, 11:59 AM
1.7ghz
Quoted: 0 Post(s)
Liked: 26
Wait? this is a Tablet pc correct?
