Wireless N Router and Wireless N USB WiFi connector only getting 64 Mbps - Overclock.net
post #1 of 4 Old 05-13-2012, 09:53 PM - Thread Starter
testsubjectx88's Avatar
Quoted: 0 Post(s)
Liked: 0
I have
This Router
http://www.newegg.com/Product/Product.aspx?Item=N82E16833124344
And
This Adaptor
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704041
The router supports up to 150 Mbps and the Adapter supports up to 150 Mbps, however when looking at the "Status" of my connection, seems I can only get 64 Mbps. I am currently running WPA2 Personal, and mixed mode. I have tried changing it to Wireless N only and it did not change anything. I am also certian the range is not a problem as the router is in the next room over, and I have even temporary moved the router only 3 feet from the desktop thats using the wifi adapter..
Any Ideas??
testsubjectx88 is offline
post #2 of 4 Old 05-13-2012, 09:58 PM
Bottleneck? What bottleneck?
Quoted: 0 Post(s)
Liked: 826
Make sure the channel width is set to 20/40 or 40 MHz.
"Just because you are a character doesn't mean that you have character." —The Wolf from Pulp Fiction
SimpleTech is offline
post #3 of 4 Old 05-13-2012, 10:07 PM - Thread Starter
Quoted: 0 Post(s)
Liked: 0
That was it!!
Being in an apartment Environment... which is better?
Auto ( 20Mhz or 40Mhz )
or
40Mhz Only
post #4 of 4 Old 05-13-2012, 10:19 PM
Quoted: 0 Post(s)
Liked: 826
Technically 40MHz but if you have some other devices that aren't compatible with that width, then put it on 20/40.
