Help setting up large home network - Page 2 - Overclock.net
post #11 of 12 Old 08-02-2013, 01:08 PM
Case Modder
Fridge Gnome's Avatar
Quoted: 0 Post(s)
Liked: 31
I had a problem similar to that. Do you have the routers under the same name? I had both my new router and my old one named the same thing, which seemed to confuse my computer on which one it should be trying to connect to. Even if only one was active.
Fridge Gnome is offline
post #12 of 12 Old 08-08-2013, 06:31 AM - Thread Starter
Dom_sufc's Avatar
Quoted: 0 Post(s)
Liked: 196
No, different names. However the other router has not been plugged in for over a week.
Anyway, update: Currently we have taken the powerline adapters out of the question, and are using Router A with the Ethernet switch. No issues so far, except a little sluggishness. We will trial this for a week to see how things are affected at peak times in the house.
Thank you for your suggestions, folks.
Battlefield 4: [OCN] Domuk89
OCN Wallpapers (Multi-res)[1] [2]
Supports resolutions 1920 x 1080 to 5760 x 1200!
Dom_sufc is offline
