How do I secure my router/system from guests? - Overclock.net
post #1 of 6 Old 08-18-2013, 11:14 PM - Thread Starter
4.0ghz
i7monkey's Avatar
Quoted: 0 Post(s)
Liked: 226
Here's my situation:
  • Have a wireless/wired router. Wireless is disabled and they're currently using regular cables for internet.
  • My router has a password
  • I don't want people roaming around on my computer, so how do I secure it?
This is how it's setup:
  • Modem is plugged into router
  • My PC and their PCs are connected at the back of the router
I've looked under network settings and I've turned OFF network discovery and public folder sharing.
I turn off "file and printer sharing" too, but whenver I restart the computer, it automatically goes back to "ON" (only for file and printer sharing, not the others).
Anyone have any insight into this? Are people who are sharing the internet using cables able to fool around on my computer? And why is the file and printer sharing always turning back on?
I have an Asus RT-N12 router and Win 7.
i7monkey is offline
post #2 of 6 Old 08-18-2013, 11:20 PM
PC Gamer
M3nta1's Avatar
Quoted: 0 Post(s)
Liked: 66
You could disable network sharing on your computer. That might work but i have no idea how deep the block would go.
If the router has some form of guest network (would prob be wireless only) that is what i would use. lets them access the internet on a different network, so they cant get to your stuff.
*EDIT* from the ASUS homepage, it sounds like it does indeed support multiple networks. So setting up a simple wireless guest network (secured, naturally) should be no problem
M3nta1 is offline
post #3 of 6 Old 08-18-2013, 11:21 PM
Database Developer
hammong's Avatar
Quoted: 0 Post(s)
Liked: 447
Easy. Disable DHCP and set the private IP addresses to something very unusual, like in the 172.168.x.x address, with the default gateway something not obvious. Anybody plugging into your switch/router would be unable to guess the gateway address, and a network sniffer would be impractical for most to figure out what it is.
Greg
hammong is offline
post #4 of 6 Old 08-18-2013, 11:28 PM - Thread Starter
4.0ghz
i7monkey's Avatar
Quoted: 0 Post(s)
Liked: 226
M3nta1, I am aware of doing a guest network, but I chose to disable Wireless on purpose so I don't get hacked by strangers from the outside, which ironically leaves me open to snooping/hacking by my guests.
I really don't know what to do.
I don't know how to do this, I'm such a noob.
i7monkey is offline
post #5 of 6 Old 08-18-2013, 11:32 PM
PC Gamer
M3nta1's Avatar
Quoted: 0 Post(s)
Liked: 66
Honestly, WPA2 is fairly resistant to hacking. Chose a strong password ( XKCD to the rescue! http://xkcd.com/936/ ) and use WPA 2 encryption and you should never have a problem. Then, you can just disable wireless when your guests leave and boom, back to being safer.
M3nta1 is offline
post #6 of 6 Old 08-21-2013, 05:22 PM
αC
AlphaC's Avatar
Quoted: 0 Post(s)
Liked: 805
In terms of easiness
(1) Disable File Sharing and let guests use the "guest network'
(2) Use WPA2
(3) Use MAC filtering
(4) Turn off DHCP and use static IPs for all users , turn off SSID
anything from then on is generally overkill
edit: also make sure you use a long alphanumeric router password.
Validation (Click to show)
4.49GHz @1.272-1.284V , 11hr Prime95
-> original
gimped BCLK (125W TDP limit)
4.6GHz@1.272-1.284V (Overvolt enabled), 14hr Prime95
4.7GHz @1.296-1.32V (Overvolt enabled), 14hr OCCT Linpack (& F19e BIOS , OCCT 11hr)
4.8GHz @1.296V
5.1Ghz @1.404V (130W TDP) .... wish it was stable
Sandy Bridge Binning guide @ HWBot
AMD Ryzen 7 1700X @ 3.925GHz 1.35V dynamic voltage ... 1hr AIDA64 (8hr AVX Prime95 with -50MHz)
W.I.P R7 1700X @ 4.040GHz (Fixed voltage is bugged , this booted at 1.39V , testing in Windows 10 PE so no GPU driver)
40.75 multi @ 1.39V
41 multi, booted @ ~ 1.41V
Recommended GPU Projects: Einstein@Home , Milkyway@Home (Tahiti , Cayman , Cypress Radeons) (AMD moreso)
Other notable GPU projects: Asteroids@Home (nvidia), GPUGrid (nvidia) , Universe@Home (Tahiti , Cayman , Cypress Radeons with double precision) (AMD)
Project list
AlphaC is offline
