would this fit a gtx 470 - Overclock.net
post #1 of 10 Old 08-21-2011, 03:51 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 38
masonkian is offline
post #2 of 10 Old 08-21-2011, 04:06 PM
Commodore 64
justadude's Avatar
Quoted: 0 Post(s)
Liked: 46
The cooler should fit on the card. The VF3000 cooler for the 470 and 480 are identical, and come with (frontplates, it's like a backplate but goes on the front of the card underneath the cooler on top of the ram/vrm) that are unique to the reference design of the cards. But you'll need to figure out 2 things, which I'd help with but it's bath/supper time for my kids.
1. You'll need heatsinks on ram/vrm and such (you'll have to make sure you cover everything you need to). You could probably buy the Arctic Cooling Acelero Plus GTX 470 ramsink kit, but I don't know about the distance between the fins of the cooler and the ram/vrm.
2. Make sure you know the distance between the fins on the bottom of the cooler and the stuff on the pcb you're trying to put heatsinks on. You can dremel the little heatsinks down to size, seems like it would be a pain to me.
Hope that helps a bit.
masonkian likes this.
justadude is offline
post #3 of 10 Old 08-21-2011, 04:12 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 106
What ^^ said.
The mounts for the physical cooler are probably the same for a 470/480, but the VRM coolers are probably different, thus why it's labeled as a 480 cooler.
hyujmn is offline
post #4 of 10 Old 08-21-2011, 04:14 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 38
Originally Posted by hyujmn;14666303
What ^^ said.
i do have some spare low ram sinks available
may go for it then what do you think ?
post #5 of 10 Old 08-21-2011, 04:17 PM
PC Gamer
superj1977's Avatar
Quoted: 0 Post(s)
Liked: 213
Im sure the core mounting holes are the same but the PCB layout for the volt regs is completely different meaning you would need another way to cool them.
Maybe you could leave the original baseplate mounted if theres enough clearance to fit the cooler with it still fixed in place over the PCB.
EDIT:
i mean similar to this MOD but obviously with your new Ebuyer cooler instead of Corsair jobby
superj1977 is offline
post #6 of 10 Old 08-21-2011, 04:19 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 38
yep used to do that when watercooling gpu block only.
if not some ram sinks should do the trick ?
post #7 of 10 Old 08-21-2011, 04:21 PM
WaterCooler
Quoted: 0 Post(s)
Liked: 132
Yes some Ram sinks will due the trick. The fans on the cooler itself should provide plenty of air flow for any RAM and VRM heatsink to work.
mdatmo is offline
post #8 of 10 Old 08-21-2011, 04:23 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 38
got to be better than stock cooling i am hitting 100 degrees load temps at the moment
post #9 of 10 Old 08-21-2011, 04:29 PM
PC Gamer
superj1977's Avatar
Quoted: 0 Post(s)
Liked: 213
Wow thats warm mate,if you use ram sinks and you use thermal tape then rub them with eraser first to get best adhesion.
Get cooler and when it comes try and mount with base plate in place,if not then slap some sinks on it.
post #10 of 10 Old 08-21-2011, 04:30 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 38
yeh will do thanks for the help guys
superj1977 likes this.
