Ongoing Pascal latency problems - Hotfix doesn't work for everyone. - Page 55 - Overclock.net
post #541 of 1679 Old 07-21-2016, 03:22 AM
boxman222's Avatar
Quoted: 0 Post(s)
Liked: 8
Originally Posted by bugsixx View Post
Seems the nvidia forum thread worked ! the Nvidia rep said the hotfix driver will be out in a few days !
It should fix the latency for all 1080/1070/1060
But what about their previous generation cards?? I really hope they don't ignore the last couple of generations even though they don't have this issue to same extent.
boxman222 is offline
post #542 of 1679 Old 07-21-2016, 04:05 AM
harney's Avatar
Quoted: 0 Post(s)
Liked: 48
Originally Posted by Cybernaton View Post
I have serious issues with Fallout 4; it is literally unplayable even with shadows lowered to medium. I have an i7 4770k and GTX 1080. I don't know if this is related, but that screenshot was when my GPU was on load (Fallout 4). I had similar issues with GTA V too, but not as severe (basically GPU utilization is low and CPU isn't being pushed as well). Fallout 4 only heavily utilizes the first core but never above 70-90%. And Dying Light and the TW3 work properly even though they are CPU intensive (Dying Light pushes all cores above 60%).
Glad you have come on here Cyber I was replying to your post 2 days ago on Nvidia forums but for some reason both of my accounts have been spammed by Nv and all my posts are hidden seems Nvidia do not like me speaking truths ...
Anyhow hope these help
I have a similar system as you 1080 i7 ect no issues for me running at 3440x 1440
What is your cpu utilisation like across all cores while in game (edit got it)
test
http://www.resplendence.com/latencymon
try windows power options to high performance
Try a couple of things
unpark the cpu
http://www.coderbag.com/programming-c/disable-cpu-core-parking-utility
try another nvidia driver than the current one
Make sure all other drivers are upto date
Re validate files for fallout in steam
There is this too add to ini
located in the C:\Users\\Documents\my games\Fallout4 and then the fallout4.ini file in there the place this under general iNumHWThreads=8
More info
https://www.reddit.com/r/fo4/comments/3sdyu7/the_old_ini_tweaks_still_work
http://steamcommunity.com/app/377160/discussions/0/496881136898870103/?tscn=1447585252#c496881136914906837
https://steamcommunity.com/app/377160/discussions/0/496881136910860004/?ctp=5
http://wccftech.com/fallout-4-performance-heavily-influenced-by-ram-speed-according-to-report/
http://www.tomshardware.co.uk/answers/id-2857248/fallout-low-fps-high-end-specs/page-2.html
harney is offline
post #543 of 1679 Old 07-21-2016, 04:10 AM
Since 1975!
mcg75's Avatar
Quoted: 0 Post(s)
Liked: 311
Yours looks the same as mine after playing.
But I play Fallout 4 and Dying Light at 4K with no issues with the same combo of hardware you have.
If you want to start another thread, I will try to help you for FO4.
mcg75 is offline
post #544 of 1679 Old 07-21-2016, 04:12 AM
harney's Avatar
Quoted: 0 Post(s)
Liked: 48
Yes good point mcg75 will both help out
I am going to test on 2 other pc's later today with FO4 with a 1070 and 1080
my own system runs fine but that is on a gsync screen so what i will do on that is disable gsync and re test that too ...
I am sure between a few of us will sort the issue
harney is offline
post #545 of 1679 Old 07-21-2016, 04:26 AM
PC Gamer
stoker's Avatar
Quoted: 0 Post(s)
Liked: 22
Thats great, just got my SC1070 installed and got this
Was this with my 7970 and no driver installed yet
stoker is offline
post #546 of 1679 Old 07-21-2016, 04:27 AM
harney's Avatar
Quoted: 0 Post(s)
Liked: 48
Welcome to the DPC club
Nvidia have stated hotfix incoming how soon not sure
harney is offline
post #547 of 1679 Old 07-21-2016, 04:28 AM
PC Gamer
stoker's Avatar
Quoted: 0 Post(s)
Liked: 22
Thanks, i knew i was buying into something big
:cheers:
stoker is offline
post #548 of 1679 Old 07-21-2016, 04:30 AM
harney's Avatar
Quoted: 0 Post(s)
Liked: 48
Yep you have to pay big to be in this niche club seems to be getting rather popular
harney is offline
post #549 of 1679 Old 07-21-2016, 05:08 AM
harney's Avatar
Quoted: 0 Post(s)
Liked: 48
Ok I have run some tests on three pc's 2 x 1080 1x 1070 with FO 4 @ 3440x1440 fully maxed all run ok tried with gsync on and off
one system i have is similar 4790k ect that run fine
also tried a 1080p & 1200p monitor all ran fine
So As Mcg75 said start a new thread i will post the results once you have done that and will all help you from there could be as simple as trying our fallout ini files swap out ect but it should work from default so could be a driver hard ware issue will see
harney is offline
post #550 of 1679 Old 07-21-2016, 05:10 AM
AMD Overclocker
Noirgheos's Avatar
Quoted: 0 Post(s)
Liked: 5
So did NVIDIA release a driver or what? Looking for a new GPU, and the 980 Ti is the same price as the 1070. According to Guru3D, the G1 Gaming 980 Ti is better than the EVGA SC 1070 I'm looking at in most games, and comparing OCs (of which the 980 Ti's is low: 1452MHz), the 980 Ti beats the OCed to 2.05GHz 1070. So yeah.
I'd rather take a newer architecture than gain 5FPS when both overclocked, but this stuttering issue is throwing me off.
Noirgheos is offline
