Graphic Problems , need help fast! - Overclock.net
post #1 of 29 Old 01-26-2006, 01:32 PM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 9
hello!
I have an veru anoying graphuc problem .. look at these pictures and you can see the problem :
http://www.rigshowcase.com/img/1939tCj1/2242
http://www.rigshowcase.com/img/1939tCj1/2241
I have done : Results:
I have tested to re-install windows Nothing
bough a 400W PSU Nothing
Trade in my graphic card in the store and geted a new one Nothing
changes drivers about 400000000 times Nothing
So for me it feels like i have been tested al sort of thing , but it dosent helps .. so what is wrong ? please help me ..!
TritoN
TritoN is offline
post #2 of 29 Old 01-26-2006, 01:35 PM
4.0ghz
13 3 @ 7 l 3 13 0 y's Avatar
Quoted: 0 Post(s)
Liked: 236
hmm, back off on your OC, although i dont see anything wrong with pic 2
13 3 @ 7 l 3 13 0 y is offline
post #3 of 29 Old 01-26-2006, 01:41 PM
4.0ghz
Quoted: 0 Post(s)
Liked: 116
i see ur problem mate...first of reset ur computer to default and run the game...see if it still remains the same...if it does and u have changed ur card check ur mobo...
if it improves then u have to slowly find a better oc point than that meaning a more stable one...but b4 u proceed further check ur temps on ur cpu and ur card...either one of that could also be a problem....
cyrixMII300 is offline
post #4 of 29 Old 01-27-2006, 12:01 AM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 9
right , when you mean reset , should i reset the BIOS ? and my card is new so i havent OC it .. and the temp is about 40 - 50C ..
TritoN
TritoN is offline
post #5 of 29 Old 01-27-2006, 06:49 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 116
yes...try resetting the computer to default bios setting and then see what happens...see if that works for u....
post #6 of 29 Old 01-27-2006, 06:49 AM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 9
right , thansk should test it .. should just go in in bios and choose to reset default settings ?
TritoN
TritoN is offline
post #7 of 29 Old 01-27-2006, 06:53 AM
4.0ghz
Quoted: 0 Post(s)
Liked: 116
thats about it mate...and restart computer and try to run the games and then see if there is a difference....let us know...
post #8 of 29 Old 01-27-2006, 08:24 AM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 9
i had reloaded default settings in BIOS and it didn´t help
http://www.rigshowcase.com/img/1939tCj1/2260 -- it still comes ..
what too doo ???
TritoN
TritoN is offline
post #9 of 29 Old 01-27-2006, 08:28 AM
PC Gamer
Ty Auchter's Avatar
Quoted: 0 Post(s)
Liked: 43
Have you checked to see if there are updates for the games?
EDIT:
Tell us what to look for in these pics because I can't find anything wrong with the third one...
some crap I've posted // LCD Temp Monitor // Eff j00 FDD LED
Ty Auchter is offline
post #10 of 29 Old 01-27-2006, 08:38 AM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 9
no i havent .. but my friends got the same game and version and everthing and they havent got the graphic problem , and it worked on my old graphic card .. please help mee
and you should look for the crazyy drawlines in the picture .. i pormise you that you will see it .. on some pictures it could be seen very easy
TritoN
TritoN is offline
