Ultimate Air Cooling - Page 3 - Overclock.net
post #21 of 30 Old 11-15-2006, 02:56 PM
In Search Of The
RyGuy's Avatar
Quoted: 0 Post(s)
Liked: 380
Originally Posted by Pinhead-227 View Post
Well, Microcenter was out of BT's today (all they have is the Mini Typhoon) so I didn't pick one up. One question for someone that owns one (BT): What are the dimensions of the baseplate?
About 40mm x 50mm by my estimations. Probably a bit bigger though.
EDIT: 67 x 50mm.
Pinhead-227 likes this.
,, ̡̡ ̴̡ı̴̴̡,,*̡͌l̡*̡̡*̡͌l̡*̡̡ ̴̡ı̴̴̡ ,͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ *̡͌l̡*̡̡̡ ̡ ̴̡ı̴̡*̡͌l̡*̡ ̡̡̡ ̡ ̴̡ı̴̡̡,,, ,,
RyGuy is offline
post #22 of 30 Old 11-15-2006, 10:31 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 156
EDIT: 67 x 50mm.
That's great! That means I can pretty easily fit a 226w pelt underneath it!
Pinhead-227 is offline
post #23 of 30 Old 11-15-2006, 10:44 PM
1.7ghz
xchrisposix's Avatar
Quoted: 0 Post(s)
Liked: 19
I have that cooler with 2 thermaltake A2017(90mm) and its like 2 inches from the rear 120mm A2018 fan. w/AS5.
The result is amazing
KEEP IT POSI.
Rig Pics!
xchrisposix is offline
post #24 of 30 Old 11-16-2006, 08:21 PM
Original OCN Gangsta
Burn's Avatar
Quoted: 0 Post(s)
Liked: 520
Funnily enough, I have a Tower 112
You're right, it could do well- you'd need to mill the lip off the base, though.
My CNC Mill Project
Originally Posted by CyberDruid
Burn + Electricty + Water =
But the man has the patience of a saint...
We cannot change the cards we are dealt, just how we play the hand.
--Randy Pausch
Current Best Benchmark
1 Million+ Folding at Home points
Burn is offline
post #25 of 30 Old 11-16-2006, 09:05 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 156
You think it'd be able to cope with a 226w peltier at 5 volts?
What is this "lip" to which you refer? What are the dimensions of the Tower112's baseplate?
Considering there's an air-cooled TEC for sale with a much less capable cooler than the Tower112 (see the link in my sig), I don't see why it wouldn't work.
post #26 of 30 Old 11-16-2006, 09:13 PM
Intel Overclocker
Quoted: 0 Post(s)
Liked: 234
i wonder if with a TT armor you could reverse the airflow on your sidefan and BT and set all other fans to intake, so i have lots of air pouring in over they components and the BT and sidefan taking it out?
What's next, banning mirrors because, oh no god forbid, if we see ourselves naked we're gunna be traumatized?
I'm like the inquirer, take everything i say with a grain of salt.
SLi Zone PSU listing- check to see if your PSU is SLi certified.
BF2 stats BF2142 stats
My Guide to BF2 Unlocks
cgrado is offline
post #27 of 30 Old 11-16-2006, 09:25 PM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 156
I'd say set it up just like you would "normally" except take into account the BT acting as an exhaust fan. You want slightly more air trying to push in than is getting sucked out (reduces dust and increases cooling efficiency).
For example, say all of your 120mm fans are of equal design and CFM. You'd want 2 front intakes, 1 rear exhaust, 1 side exhaust (BT) and your PSU as exhaust. I'd say that'd be pretty much as "optimum" as it could possibly get without a "straight through" ducting design with a tower heatsink. That takes into consideration the "resistance" that the heatsink itself has to airflow through your BT exhaust fan.
Also remember that when ducting hot air out of a case, you don't want any air leaks. That will throw off your airflow/pressure and allow hot air to "recirculate" through the heatsink. It would be about the same (if not worse) than "normal" cooling. **been there, done that**
post #28 of 30 Old 11-17-2006, 04:59 AM
Burn's Avatar
Quoted: 0 Post(s)
Liked: 520
There is a small lip machined into the base, I don't know why, but it exists, it would need to be milled off to allow the TEC to make full contact.
It's less than 1/16th of an inch, so it's not too big, it would mill off quite well. I could do it when I get my mill running, too.
My CNC Mill Project
--Randy Pausch
Burn is offline
post #29 of 30 Old 11-17-2006, 05:17 AM
Back From The Dead
Namrac's Avatar
Quoted: 0 Post(s)
Liked: 701
Scythe Infinity should work well...
20110813 - RIP
Take me out into the black, tell them I ain't coming back.
Burn the land and boil the sea, you can't take the sky from me.
Namrac is offline
post #30 of 30 Old 11-17-2006, 10:17 AM - Thread Starter
4.0ghz
Quoted: 0 Post(s)
Liked: 156
It definately seems to have the most heat dissipating capability, but the way it's built makes the fans point "up" on my motherb0ard and wouldn't help me any with my ducting.
