anyone with a thermaltake xcontroller? - Overclock.net
post #1 of 1 Old 02-20-2006, 07:21 PM - Thread Starter
333mhz
mrpringle's Avatar
Quoted: 0 Post(s)
Liked: 0
I went out and bought a thermaltake xcontroller which I think may be faulty.
I have 3 fans connected on 3 seperate channels, but I am finding there is very limited room for fan speed adjustment. For example, if I set one of the channels to the minimum voltage, then turn the knob a fraction it will light up green, then turn it a fraction again, and it will light up red. After it is red I can turn it about 270 degrees to max.
Is this the normal behaviour for this fan controller, or have I got one which is faulty?
Thanks
mrpringle is offline
