Need to cool down my room - Overclock.net
post #1 of 26 Old 06-07-2010, 05:08 PM - Thread Starter
1.7ghz
Shibster216's Avatar
Quoted: 0 Post(s)
Liked: 8
Its summer time now and I have had it with these room temps. I know that having a computer like mine in my room will always make the room warm, but there has to be something I can do to keep it a little cooler. When you walk in my room you can immediately notice a difference in temperature around 10-20 degrees in summer. I have a ceiling fan and a portable fan, but I still cant keep my room as cool as the rest of the house, which is actually liveable.
I have absolutely no knowledge of cooling, aside from knowing when things get too hot. Is there anything I can do to get the room temperature down even a couple degrees, maybe another heatsink for my CPU other than the stock, more fans, or convert my room into a freezer...
Flight Sim Pilots
Shibster216 is offline
post #2 of 26 Old 06-07-2010, 05:12 PM
Killhouse's Avatar
Quoted: 0 Post(s)
Liked: 178
Improving the heat dissipation from your computer isnt going to help your room temperature. Although the computer may be cooler, it's just because it's moving that heat into your room.
The only way to reduce the temperature in your room through your computer would be to undervolt the CPU so that it's not producing as much heat.
If you've got money to spend you could look at an Air Conditioning unit, otherwise I just recommend sitting in your boxers with a massive desk fan pointed at you
~ Killhouse's Worklogs ~
COMPLETE: Paroxysm :: Scratch ATX Acrylic Case Worklog
COMPLETE: Eyas :: Scratch mITX Acrylic HTPC Case Worklog
COMPLETE: Computer Desk :: Large Computer Desk
~ Clubs ~
Owner of The Official Corsair H50 Hydro Series Club
Killhouse is offline
post #3 of 26 Old 06-07-2010, 05:14 PM
coolrock6644's Avatar
Quoted: 0 Post(s)
Liked: 14
Adapt to the heat. Then when really hot days come, after sitting in your molten room it will feel nice and cool.
Computer building course?
Do they also have a course for making sandwiches?
coolrock6644 is offline
post #4 of 26 Old 06-07-2010, 05:17 PM
4.0ghz
JMT668's Avatar
Quoted: 0 Post(s)
Liked: 101
Point your PC out the window?
JMT668 is offline
post #5 of 26 Old 06-07-2010, 05:17 PM
HEY, PAUL
meticadpa's Avatar
Quoted: 0 Post(s)
Liked: 1389
Yes... as Killhouse said, getting a better cooler for your computer (or even water cooling) would not do anything to the temperature of your room since the same amount of heat is being dissipated into the the air, just more effectively.
Other than air con, there's not really anything you can do.
meticadpa is offline
post #6 of 26 Old 06-07-2010, 05:17 PM
Intel Overclocker
adzsask's Avatar
Quoted: 0 Post(s)
Liked: 100
window a/c unit is your cure i put a sweater on in my pc room
adzsask is offline
post #7 of 26 Old 06-07-2010, 05:22 PM
Amiga 500
Ysbl's Avatar
Quoted: 0 Post(s)
Liked: 88
Put your pc in a fridge.
Lolololololol, but honestly, invest in a WC loop.
Ysbl is offline
post #8 of 26 Old 06-07-2010, 05:27 PM
Killhouse's Avatar
Quoted: 0 Post(s)
Liked: 178
This wont help, as we all just said.
A WC loop will just more efficiently move the heat from the computer to the air in the room, it's not going to cool his room down
~ Clubs ~
post #9 of 26 Old 06-07-2010, 05:49 PM - Thread Starter
1.7ghz
Quoted: 0 Post(s)
Liked: 8
Well thanks for the info guys. Even with the AC on, and my 2 fans its till pushing 85 in my room right now.
Flight Sim Pilots
post #10 of 26 Old 06-07-2010, 05:52 PM
Handsome.
DaClownie's Avatar
Quoted: 0 Post(s)
Liked: 287
Based on your sig rig, with an AC running it shouldn't be 20 degrees hotter in your room. I'd suggest getting a better air conditioner, or, insulating your walls.
R.I.P. Syrillian - August 13, 2011
Amazing during your time here on earth, but your calling in heaven must be extraordinary.
About drbaltazar's translated posts:
i like the!new GPU from AMD!this discovery( could mean !alot ! i like grapes!
DaClownie is offline
